Results 1 to 17 of 17
Thread: Carbureted Engine Problems
    Sep 2021
    1987 honda accord lx
    I am having a few problems and I am not sure why or how to fix them. I thought you guys might know. The first problem is the engine will stall every time I don’t let the engine warm up to operating temperature before I start driving. Since it is a carbureted engine is this a normal thing that I have to deal with or can I fix this? The other thing is that it idles a little bit too high, around 1500. I couldn’t find if there was some kind of thing to adjust to fix this. Again maybe you guys know, Thanks!
    Re: Carbureted Engine Problems
    Check that the choke is operating, it should close on a cold start and open up as it warms, it will probably increase the idle while its on. Wait for it to open and then check the idle, there is a black knob on the left side of the carb that you turn to set the idle speed. maybe keep the choke open and cold start it, give it just a minute to warm up and then see if it has any issues stalling, my car had the choke wired open since I got it, so it never worked and I never needed it, don't know if there was something wrong with it.
    Check for vacuum leaks.
    LX User Jinnai's Avatar
    Jul 2020
    Colorado Springs
    Did anything happen when this started? When was the last time it didn't have the stalling problem?
    Do you mean it stalls while driving in general, or do you mean only if you leave it to idle while cold and you could get around it by holding down the gas pedal a little bit during idle? If it's the second, then I second that it's temperature idle control is wacked, I think.
    Sep 2021
    Quote Originally Posted by Jinnai View Post
    It doesn’t stall while idling, I’m assuming because of the auto choke. But if i’m not patient and start driving it before it is warm enough, then it will stall in general driving. It did not do this the first time starting after a year or two, but that first start was also 2 months ago. I live in Utah, it starts getting colder from now till late January maybe. So it was also a little bit warmer on the first start.
    But ya, it’s been doing it ever since. Though the auto choke does work on the initial start when the engine warms up, I don’t if it is also supposed to be working while driving; and don’t know if that is what is causing problems.
    Spray short squirts carb cleaner around the base of the carb while the engine is running and under the air filter box, if the idle changes you have a vacuum leak probably on one of the hoses.
    Sep 2021
    This could be completely unrelated, or maybe not.
    All the sudden, one morning my car decided to stop starting, and it has been doing it every since. Every few tries I can get it where it kinda wants to go but it doesn’t completely start. The engine is cranking just fine but it won’t start, meaning the battery is good. I also checked the distributor and cables and they were working good too. The next big thing I would think is the fuel pump or fuel filter. Could this maybe be caused or related to the problems with my carburetor that I have been seeing before?
    Is there gas in the float bowl?
    Sep 2021
    I won’t be able to check till tomorrow, but i’m assuming it’s just some kinda valve to check right?
    There is a sight glass on the driver side of the carb. You can also take the fuel hose off the carb, some gas should be sitting in the line. You should be concerned if there isnt gas there, next place to check would be the small filter that should be about a foot away from the carb.
    Nov 2021
    1988 Honda Accord LX
    Hey! I have the same problem with mine. Does your idle drop to normal when it's put into gear and then the idle rises when it's put back into park? I assume it's either a carb adjustment needed or something to do with the butterfly valves
    Did you read the other replies?
    Sep 2021
    Yes, I finally was able to find time to check. The level is just below the tip of metal in front of the glass.
    Sep 2021
    Although there is fuel in the bowl and lines, there is not enough pressure. When doing a pressure test the psi didn’t budge at all. Meaning that the filters aren’t bad because there would be at least some pressure.
    I then worked towards the fuel pump, I checked the voltage of the fuel pump connector and only got 9.50-9.60. I was told that the pump could still run, (it does) but maybe doesn’t have enough power to keep good pressure.
    This could be the problem, but I also could be measuring the voltage wrong. I am just connecting the positive and negative leads of the multimeters to the connector. (connected terminal 1 and terminal 2 in fuel pump relay to receive constant power to fuel pump)
    I really hope this isn’t the problem lol.
    Edit: My massive service manual says that if the pressure tests fails then you should just go straight to replacing the fuel pump. It doesn’t mention the connector or power to the fuel pump anywhere either. Is there something I don’t know?
    Quote Originally Posted by asianwills View Post
    There is a relay that turns the pump on and off I think it right on the fuse box under the dash. I would look at that since you have voltage but it is low its usually a bad connection some place.
    Double check your self and check the battery voltage as well fully charge it should be above 12.5 volts DC.
    Sep 2021
    It is ok to start my engine a few times when the carburetor air box is completely pulled off? I just need to test a few things and to see if it will even start. With the carburetor box fully of there is some hoses and vacuum lines disconnected.
    The ones on the air box go to open air basically, I dont think they are super important. you can start it with a vacuum leak anyway, if one of the lines is sucking then you can plug it.
  1. Replies: 4
    Last Post: 09-05-2021, 07:20 AM
  2. Alternator on a 88 Accord DX Carbureted
    By vVSmileyVv in forum Carburetor Tech
    Last Post: 04-30-2014, 09:55 PM
  3. Main fuel relay on a carbureted LX?
    By ItsaHonda in forum 3geez Accords
    Last Post: 07-20-2013, 07:00 PM
  4. [Electrical] Carbureted Distributors: Identifying TEC or Hitachi
    By 2ndGenGuy in forum Frequently Asked Questions
    Last Post: 11-13-2012, 08:08 PM
  5. Oxygen Sensor On 87 Accord Carbureted
    By Hondaisok in forum Carburetor Tech
    Last Post: 12-06-2005, 11:54 PM
