Results 1 to 4 of 4
Thread: 1988 Honda Accord LX high idle
    Nov 2021
    Hey guys I had this problem with my 88 and was wondering if you guys would know what's wrong. When I start the car up, it idles high which is no problem what so ever. However, the idle stays at about 1500 and doesn't drop. When I put it into drive or reverse, it drops to normal idle speed. When I put it back into park, the idle rises again to 1500. Do you guys know what's wrong or could it be something to do with a butterfly valve/bad carb. The carb was replaced less than 1,000 miles ago though. Thank you guys so much.
    Re: 1988 Honda Accord LX high idle
    https://www.3geez.com/forum/showthre...Black-Box-info
    id read thru this thread. I under stand its a little wordy but it has some meaningful info on it. I would also follow the manual which can be downloaded here.
    The idle can be turned down but I suspect its turned up because the car was stalling.
    Since the carb was put on less than 1000 miles I would at some installation mistakes like a vacuum leak or the throttle linkage is set too tight.
    Check for vacuum leaks.
    Nov 2021
    Thank you! This will definitely help.
  1. 1988 Honda Accord LX high idle
    By amansalman in forum 3geez Accords
    Last Post: 01-16-2022, 09:41 PM
  2. Replies: 17
    Last Post: 07-13-2018, 08:38 PM
  3. Replies: 1
    Last Post: 01-09-2013, 03:03 PM
  4. New 1988 Accord lx 5 spd, high idle? 135k
    By IllEuropeans in forum Carburetor Tech
    Last Post: 10-20-2011, 06:42 PM
  5. 88 accord high idle
    By cl88 in forum Carburetor Tech
    Last Post: 04-05-2005, 01:07 PM
