Results 1 to 4 of 4
Thread: 1986 Accord LXi 2.0 Automatic Transmission issues
    Apr 2015
    1986 Accord LXi
    Hey all, have an automatic transmission question for you guru's. Having a shuddering issue when trans tries to shift between 1 and 2nd. After it hits second gear it's just fine and shifts normally. No weird smell from the fluid. Haven't done a filter and fluid change yet, but I'm thinking clutch and pressure plate. Any ideas? Car has 214k miles on it.
    Re: 1986 Accord LXi 2.0 Automatic Transmission issues
    Check your fluid level first.
    Apr 2015
    1986 Accord LXi
    fluid level is good.
    Probably some damage in the valve body then. There are only really 3 things you can do with these autos.
    1. Do a flush and hope for the best
    2. Play with the TV cable adjustment
    3. Rebuild it
  1. Replies: 5
    Last Post: 02-15-2014, 07:59 PM
  2. Automatic Transmission Problem - Accord 3rd
    By Teratani in forum 3geez Accords
    Last Post: 10-20-2007, 07:43 AM
  3. 86 accord lxi automatic f4(h4) transmission
    By 86-accord-lxi in forum 3geez Accords
    Last Post: 11-04-2005, 05:38 PM
  4. 89 Accord Automatic Transmission Swap from Prelude
    By 89AccordLX in forum 3geez Accords
    Last Post: 10-27-2002, 10:44 AM
