Results 1 to 2 of 2
Thread: Fuel leak from top fuel screw.
    DX User Puncake's Avatar
    Feb 2022
    1989 Honda Accord DX Hatch
    Tucson, Arizona
    Hey all, I'm having a problem with my top fuel screw. Its leaking buttloads of fuel. I've tried changing where it sits and it just keeps leaking the same amount. never really feels tight no matter which way i turn it unless its fully up. Is there a way to replace it? i even bought a carb from the junkyard so I had a replacement if I could find a way to replace it. I backed the junkyard one out and used it's amount of turns to retighten the screw on the carb on the car. any help would be appreciated
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: Fuel leak from top fuel screw.
    Yes, that is a common failure. You need to take the screw out and replace the orings. No amount of changing or moving the screw will help, theyre all 35 years old and flattened. I wish I knew what size they are off the top of my head, most of the off the shelf ones that I have found are too thick, but if you find one that is really close then you can sand down the outside until it fits. You can also find the diameter and a close thickness then order the next 1 or 2 thickness down from here https://www.mcmaster.com/o-rings/oil...a-n-o-rings-8/
  1. air/fuel mixture screw
    By Neuspeed87lx in forum Carburetor Tech
    Last Post: 04-05-2005, 07:08 PM
  2. Fuel/Air Mixture Screw
    By sbHatch86 in forum Carburetor Tech
    Last Post: 10-06-2004, 10:08 AM
  3. **Attn Carbed PPL!** A/F AF Air Fuel Mixture Screw
    By 87accordlxph in forum Carburetor Tech
    Last Post: 07-14-2004, 02:19 PM
  4. air/fuel mixture screw
    By Mykii in forum 3geez Accords
    Last Post: 03-02-2004, 05:56 PM
  5. Air/Fuel Mixture Screw? Where?
    By mindlos in forum Carburetor Tech
    Last Post: 10-11-2002, 01:20 PM
