Results 1 to 8 of 8
Thread: Head bolts
    Mar 2022
    1988 Honda Accord LXi
    Head bolts
    Trying to rebuild the short block on an A20A3. Need head bolts/studs. I found the ARP 218-4073 number....not available. I have the pistons, rings, head gasket coming this week. Anyone know where I can get the head bolts? Really don't want to reuse the old ones.
    Re: Head bolts
    Quote Originally Posted by stvntc View Post
    I wouldnt hesitate to reuse the old ones. I never have read they are torque to yield type bolts.
    https://www.summitracing.com/parts/arp-218-4701
    the part number you put for the studs look like they are available at Summit.
    EDIT: Sorry very weird I put in your part number in google and the 4701 number comes up
    Re: Head bolts
    You can reuse them no problem. I mean, replace them if they're obviously damaged or if you're going with a high boost application, but otherwise the ones you have will be fine.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: Head bolts
    Reusing them might be fine, but I do suggest the head studs. The stock bolts are very low torque and the head gasket would likely perform better with them.
    They are still available.
    https://www.summitracing.com/parts/arp-218-4703
    https://www.jegs.com/i/ARP/070/218-4703/10002/-1
    https://www.vividracing.com/arp-head...2-p-64742.html
    Mar 2022
    Re: Head bolts
    I did find them at Jeg's. I ordered them, unfortunately they are on backorder. Going to have to reuse the old ones this time around.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: Head bolts
    If they come in they are at least something you can replace one at a time
    Mar 2022
    Re: Head bolts
    I want to thank you guys for the input on the head bolts. I reused the old ones and just got the car running again. Should be road worthy this week.
    Re: Head bolts
    Yay!
  1. Head Bolts
    By Griff in forum 3geez Accords
    Last Post: 01-26-2016, 07:21 PM
  2. Head Bolts?
    By Crazy_C in forum 3geez Accords
    Last Post: 08-13-2012, 03:19 PM
  3. ARP Head Bolts
    By LiTtLe xOx BitT in forum 3geez Accords
    Last Post: 02-17-2007, 10:59 PM
  4. head bolts!
    By 86lxiricer in forum 3geez Accords
    Last Post: 02-03-2005, 04:24 PM
  5. head bolts
    By nappyroots827 in forum Performance
    Last Post: 10-13-2004, 09:39 AM
