Results 1 to 10 of 10
Thread: 87 accord fuel lines
    Apr 2022
    87 Honda accord
    I just bought an 87 accord the whole fuel system was just redone by the people before me but he messed up the high pressure fuel line i was wondering if anyone knows what size that line is and or knows where i can get one
    Apr 2022
    87 Honda accord
    Re: 87 accord fuel lines
    It’s a 87 LXi
    How exactly is it messed up? Just fyi replacing the fuel line basically means you need to take out the entire interior including the dash.
    Apr 2022
    87 Honda accord
    I’m not exactly sure i just got the car yesterday the dude told me that when he did the fuel pump he tugged on the high pressure fuel line and messed it up now it pisses fuel everywhere. He also told me it’s a discontinued part from Honda too
    I believe its a 3/8" hard line, at least it is on my dx. It might be easier to see if you can do some kind of patch repair or cut the bad section out and put a bubble flare and a piece of hose inline.
    Apr 2022
    87 Honda accord
    So do you think i could cut the section it’s leaking from then get 3/8th rubber tubing with some clamps and just clamp it
    Quote Originally Posted by Cjtux2000 View Post
    Short answer:
    I say no because the fuel pressure coming out of the pump is about 35 psi and can go higher easily on that style pump. I dont think standard clamps will work.
    My long reply is you may want to research what the newer 90's Honda/Acura cars did. I think they run the fuel line under the car protected. That maybe an answer. Id very much like to re do mine since I run E85 and need larger lines and don care much for banjo type fittings.
    I have had oem fuel injected cars with regular hose clamps on the main fuel line, but I would not just cover the broken area, it needs to be properly fixed with a flare. If one is still worried about leaks you could probably even use a double flare and a coupler like you would see on a brake line.
    Under the car is an option, but you do not have much way protection there
    Apr 2022
    87 Honda accord
    Do you know what size banjo bolt it is for the fuel line? It’s missing it completely and that’s probably my leak
    Guessing its 8 mm. Use new crush washers top and bottom.
    https://clearwaterhydraulics.com/met...3_276_304_432/
  1. '87 Accord LXi Gas Tank/Fuel Pump/Fuel Lines
    By peakylight in forum 3geez Accords
    Last Post: 12-06-2020, 07:56 AM
  2. NEED HELP (85 accord) No fuel.
    By PORTnPOLISH97 in forum 2geez Accords
    Last Post: 02-01-2008, 11:10 PM
  3. Fuel Lines????
    By bigbrat41 in forum EFI Tech
    Last Post: 03-04-2007, 11:33 PM
  4. HELP:vaccum lines map for carbed 89 accord
    By twofast4u in forum 3geez Accords
    Last Post: 04-30-2006, 11:40 AM
  5. help fuel lines
    By b20a86lude in forum Performance
    Last Post: 11-24-2004, 10:21 AM
