Results 1 to 3 of 3
Thread: Rusty fuel tank
    Apr 2021
    Honda Accord 1986 2.0 78kw
    Lithuania
    Rusty fuel tank
    Hello, I have problem with my 1986 2.0ex accord. The fuel tank is wery rusty from inside. So I want to ask how to clean it, because I dont get new anywhere? And does here fits fuel tank from another honda?
    Re: Rusty fuel tank
    Quote Originally Posted by bropniukas View Post
    Carburetor gas tank are available new.
    There are some chemical treatments you can use or look into electrolysis using soap power and a battery charger.
    carotman's Avatar
    Montreal South Shore
    Re: Rusty fuel tank
    Well, you being from Lithuania, I don't know the parts supply situation where you live.
    However, there are several options available to you, depending on your budget of course.
    Where I live, radiator repair shops usually also repair motorcycle and vintage cars fuel tanks. The price isn't cheap but it's not too expensive either. When no new fuel tank is available, this is a nice option. They will remove the rust with special chemicals and coat the inside of the fuel tank with an epoxy coating what will withstand gasoline.
    You can buy a fuel tank rebuild kit online and do it yourself. This should in theory be much cheaper.
    This one comes to mind: https://caswellplating.com/epoxy-gas-tank-sealer.html
    It all depends on the condition of your current tank. If it's really rusty and is beyond repair, you can always get a good used one online.
    I need these parts!
  1. '87 Accord LXi Gas Tank/Fuel Pump/Fuel Lines
    By peakylight in forum 3geez Accords
    Last Post: 12-06-2020, 07:56 AM
  2. Fuel tank and fuel Filler neck hose connections
    By Demon1024 in forum EFI Tech
    Last Post: 06-05-2017, 05:01 PM
  3. Replies: 10
    Last Post: 09-30-2015, 07:05 PM
  4. dirt fuel tank keeps clogging fuel filters
    By lamontlamont in forum 3geez Accords
    Last Post: 12-12-2005, 10:52 PM
  5. WTB: fuel tank for EFI
    By hootymo in forum Trading Post
    Last Post: 02-06-2004, 06:55 PM
