Results 1 to 5 of 5
Thread: 1987 LXi Hatch brake lights...
    Oct 2019
    1987 Accord LXi hatchback
    So I'm pretty sure my brake lights worked before all this. I usually back into a spot in the morning to park for work and I see the wall behind light up red when I touch the brakes. That changed after I messed with the retractor in my passenger door.
    The other day I took it upon myself to finally try and get the retractor in my door to stop clicking and get the light of my dash that is always on. I had read on some forum about unplugging them and using a paperclip as a jumper. So I tried to do it from memory and wound up sticking the paper clips in the retractor connection on the harness NOT the plug under the seat as the forum said...
    Now my dash has this incessant flashing seatbelt light and a seatbelt/door light on. The other thing is that the brake lights don't work. I was reading on the forum that I could pull the fuse for the retractors to stop all the stuff that was happening but also read it kills your break lights. So naturally I checked my brake lights to see if they worked after I pulled the fuse and also when I replaced it and they didn't work. I also replaced it with another fuse to make sure I didn't put a bad one in or blow it when I was jumping wires. I also replaced the bulbs.
    As the car sits now there's no jumpers and everything is plugged back in the way it was. Still no brake lights. I know they worked before. I'm worried I burnt something up in the harness or maybe on a circuit board? I was thinking it makes sense the brakes are connected to this circuit somehow because of the seatbelts locking when you press on the brakes possibly.
    Oct 2019
    Re: 1987 LXi Hatch brake lights...
    Solved... It was the fuse under the hood
    Oct 2019
    Good job...im a little surprised the re-tractor for the seat belts and the brake lights are on the same fuse under the dash.
    Sep 2021
    87 Lxi Hatch manual
    In case anyone else sees this thread. Your horn also won't work if this fuse is blown.
  1. 1987 Accord LXi rough idel at stop lights
    By swread in forum EFI Tech
    Last Post: 03-21-2021, 05:30 AM
  2. 1987 lxi hatch scrap or parts 300$
    By 203lxihatch in forum Ebay & Craigslist Finds
    Last Post: 06-25-2013, 01:24 PM
  3. 1987 Accord LXi 3d-hatch (sell it or fix it?)
    By tallazzFilipino in forum EFI Tech
    Last Post: 11-28-2005, 08:17 PM
  4. 1987 honda accord lxi hatch
    By HondaBoy334 in forum General Engine Swaps
    Last Post: 12-11-2003, 02:14 AM
  5. 1987 LXI hatch AC!!!!!!
    By PogiLXI in forum Trading Post
    Last Post: 08-15-2003, 10:51 PM
VigLink badge
