Results 1 to 8 of 8
Thread: A20A1 small oil leak coming from rear of motor
    DX User RI86DX's Avatar
    Jul 2022
    1986 Honda Accord DX, A20A1 4SPD AT
    Rhode Island
    As the title says. It's dripping down onto a hose of some kind (heater hose?) and my PS rack. Seems to only leak when the car's been sitting for a while after being driven. Any ideas?
    Re: A20A1 small oil leak coming from rear of motor
    hard to say with out a picture but the distributor has an O ring seal that can leak oil out.
    Jul 2022
    Rhode Island
    Was thinking the dizzy O ring or the 2 seals behind the tbelt cover, those seem to be very common spots for both the A1 and A3 to leak oil from.
    If it is really just the rear of the engine...towards the firewall. The oil filter housing has a figure 8 O ring that can go bad.
    Jul 2022
    Rhode Island
    Alright, I'll keep that in mind as well.
    Don't forget about all the PCV hardware back there that develops leaks.
    Check the oil pressure switch.
    Pcv is also through the rear, specialty hose with two different IDs
    Jul 2022
    Rhode Island
    Thanks for the tips, ever since I had a new pan/pan gasket put on the car the leak has become really tiny. It was a lot worse before then. BTW is synth blend oil bad for these cars? Paranoid that it's going to gum my motor up or make it leak even more oil.
  1. Small gas leak...is it the fuel filter?
    By SeanSelander in forum EFI Tech
    Last Post: 05-13-2012, 12:48 PM
  2. Oil leak Found.. now an even worse oil leak....
    By Christofur in forum 2geez Tech & Performance
    Last Post: 03-11-2011, 08:46 PM
  3. A20A1 oil leak! need advice.
    By Pana23 in forum Carburetor Tech
    Last Post: 01-21-2006, 07:30 PM
  4. small leak
    By LiTtLe xOx BitT in forum Classic Honda Community Chat
    Last Post: 10-25-2005, 11:30 AM
  5. Small oil leak
    By Accord 06 in forum Performance
    Last Post: 12-12-2003, 07:46 PM
VigLink badge
