Results 1 to 3 of 3
Thread: Brake light on dash after replacing bulbs with LEDS.
    Sep 2021
    87 Lxi Hatch manual
    Sonoma County, California
    Hello everyone. I replaced all of my taillight bulbs with LEDS and obviously my car thinks the bulbs are burnt out and the light is on on the dash. Is there any way to get rid of this? I've taken the cluster out a few times and would just remove the bulb but it's part of something more complicated. I'm not switching back to dim regular bulbs so don't suggest that please.
    Re: Brake light on dash after replacing bulbs with LEDS.
    Quote Originally Posted by Gabezermeno View Post
    Its looking for resistance and LEDS are too low in resistance.
    I had to use solid state relays as well to make my blinkers work on another vehicle just to note.
    conozo's Avatar
    1988 Honda Accord DX, 250,000 Miles, Daily Driver
    Fort Wayne, Indiana
    There is a Bulb Check Circuit that is located on the dash instrument panel. I would get the shop manual and take a look at the instrument panel to see where this bulb check circuit is. I'd look at the circuit to see how it works. Maybe its changing out a resister, maybe its disabling the circuit all together by disconnecting a component. I'd have to see it to give you a real answer.
    The only other solution i have heard but dont know much about is adding resisters to the led bulbs, i assume thats in parallel so that the bulb and resister both use enough power for it to think the bulbs are working. This solution is something i have heard about people doing for all cars when upgrading to LEDs, not just for these hondas, it was mainly to get the turn signal to blink normally and not super fast but it might fix this issue also.
    1988 Honda Accord LSDX-I
  1. Dash Brake light
    By Rendon LX-i in forum 3geez Accords
    Last Post: 10-20-2012, 12:37 PM
  2. Dash Light: Brake Light Out
    By ArokASE88LXi in forum 3geez Accords
    Last Post: 05-11-2009, 06:57 PM
  3. Dash Brake Light Problem
    By mushroom_toy in forum 3geez Accords
    Last Post: 08-27-2007, 08:37 PM
  4. Brake warning light on dash lit up?!?!?
    By Brettmans5 in forum 3geez Accords
    Last Post: 07-07-2003, 12:46 AM
  5. Replies: 12
    Last Post: 10-01-2002, 05:15 AM
Tags for this Thread
