Results 1 to 3 of 3
Thread: Connecting rod and bearing wear questions
    DX User temrinal's Avatar
    Aug 2022
    '89 Honda Accord LX
    Wichita, KS
    So after my plastigage came in, i decided to swallow my pride and get under there and start on replacing the bearings. I opened up the cap on cylinder no.4 (or 1, farthest from the crank pulley) and the crankshaft looked fine, but I cant tell what bearing wear pattern this is and what it means, i got 228k so possibly normal wear? The backside of the bearings were absolutely zebra print, and the cap had alot of (What i think to be bearing material?) on it, under the bearing. I need to find a way to get it off, and also, get it off on the actual big end of the connecting rod surface, as it was under the bearing on the big end too. the wear looks fairly similar on both bearings if im not mistaken. Anyone got tips to cleaning them surfaces off, without yanking the thing out and doing a full rebuild? and also, could anyone tell me what bearing wear pattern this is? I coated the cap surface and big end rod surface with oil on the cap and wd40 on the big end so nothing rusts while i got the bearing out. But like i said, i never had knock and the crank looked pretty fine, no obvious visible damage yet, but ill run my fingernail over it tomorrow, or once i find a way to clean off the conrod surfaces. If I cant get this pos running, and i give up looking for a motor, i think im just gonna sell it. I attached some images of everythin. green color is uv oil dye. thanks again everyone.
ID:	11167   Click image for larger version.
ID:	11168   Click image for larger version.
ID:	11169   Click image for larger version.
    '89 Honda Accord LX
    LX User RI86DX's Avatar
    Jul 2022
    1986 Honda Accord DX, A20A1 4SPD H4F4 AT
    Rhode Island
    Re: Connecting rod and bearing wear questions
    Quote Originally Posted by temrinal View Post
    I wouldn't do that if I were you unless you want one of the I BUY JUNK CARS/car donation scumbags to junk another perfectly savable pre OBDII car.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Uuuh hard to get a hold on what is really going on here, I think you are saying that there is bearing material left on the rod. You can use light abrasives like a scotch Brite pad or a razor blades, it's just important to not leave any high spots, like if you knick the edge it could leave a mark that can interfere with the bearing laying flat, same as if you removed the bearings with a screwdriver. Just fix it if you mess it up in any way, it's not rocket science
  1. diy rod bearing change
    By 1987AccordLx-i in forum 3geez Accords
    Last Post: 03-28-2009, 05:44 PM
  2. B18 Connecting Rod Question CROWER & EAGLE
    By adams86lxi in forum Classic Honda Community Chat
    Last Post: 08-27-2008, 11:35 PM
  3. Rod bearing clearances...
    By 2ndGenGuy in forum 1geez Tech & Performance
    Last Post: 01-10-2007, 07:03 PM
  4. Connecting rod play?
    By BITESIZE in forum EFI Tech
    Last Post: 03-28-2006, 09:58 AM
  5. Rod Bearing problems...
    By AccordEpicenter in forum Performance
    Last Post: 08-31-2003, 02:49 PM
Tags for this Thread
