Results 1 to 13 of 13
Thread: PCV valve location? 86 Accord
    Nov 2022
    1986 Honda Accord LX 4 door A20A1 with 5 spd manual
    Vancouver
    1986 Accord LX with carbs and manual transmission. I am wanting to replace the PCV valve as preventative maintenance, but I can't find it. Looking at the rudimentary drawing in the shop manual, it appears to be located between the engine and the firewall. I have purchased the replacement PCV valve, so I know what it looks like. But I still can't find it. Any suggestions?
    Thank you in advance for any and all help.
    LX User RI86DX's Avatar
    Jul 2022
    1986 Honda Accord DX, A20A1 4SPD H4F4 AT
    Rhode Island
    Re: PCV valve location? 86 Accord
    A20A1 should only have one carb...you sure it's not a different motor?
    Nov 2022
    Vancouver
    Yes a single stock carb. My bad for not being more precise.
    Everything is factory stock. We are the original owners of the car and there has been no modifications to anything.
    Nov 2022
    Vancouver
    This is a photo of the replacement PCV valve. It measures 1 and 3/4 of an inch. I can't find anything like it under the hood. Hopefully they sold me the correct one.
    Quote Originally Posted by Gunter View Post
    The hose goes to the valve cover try following it back to the intake manifold. The PVC is in the intake manifold someplace.
    Nov 2022
    Vancouver
    That's where I have been looking, but I can't find it. I will try removing the air filter assembly to get a better view.
    I think the underhood sticker should show it.
    Sorry I dont have a carbed car and havent worked on one in a long time.
    Nov 2022
    Vancouver
    Unfortunately the under hood emissions sticker isn't of any help. No diagram and no mention of a PCV. This is a Canadian edition so the top half is in French and the bottom half is in English.
    Next weekend I will try pulling off the air filter assembly to get a better look.
    Nov 2022
    Vancouver
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    It's basically dead center of the intake manifold. 1 big hose coming off it, I believe it's a U shaped hose.
    I would actually be careful replacing it, those hoses will crack and you can't replace it with normal hose due to the silly shape. I'd return the valve even, not a lot to go wrong in a metal valve with a ball and a spring in it... If it was ever stuck carb cleaner and a small amount of blunt force will fix it
    Nov 2022
    Vancouver
    That sounds like good advice. I think I will leave it alone until it starts to cause some problems.
    Getting parts for this car is becoming challenging and I don't want to break anything during the disassembly process.
    I also found this post which basically says the same thing i.e. parts are brittle
    https://www.3geez.com/forum/showthre...valve-location
    "it is right in front of the carb, there is a hole made in the manifold there and you will see a U shaped short fat hose. the pvc is directly under that hose. There is a hard plastic tube that snaps in that hold made in the manifold from underneath. Careful because all that is brittle."
    Nov 2022
    Vancouver
    Thanks for all the help. It is greatly appreciated.
    Jul 2022
    Rhode Island
    Ah, gotcha. Sorry for sounding pedantic.
    As far as parts availability, Rockauto & Ebay. Apparently RA doesn't ship to Canada so that sucks.
  1. location for my pcv valve 86 lxi
    By 1skatingrink in forum EFI Tech
    Last Post: 01-16-2013, 11:04 PM
  2. pcv valve location
    By evil88accordLX in forum 3geez Accords
    Last Post: 10-15-2008, 08:58 AM
  3. PCV Valve location?
    By ccotm in forum Classic Honda Community Chat
    Last Post: 09-20-2006, 02:30 PM
  4. PCV Valve Location
    By LocoPico in forum EFI Tech
    Last Post: 08-23-2004, 09:15 PM
  5. location of PCV valve
    By formula_mango in forum 3geez Accords
    Last Post: 07-26-2002, 08:54 AM
