Results 1 to 12 of 12
Thread: Need help Accord 87 Ex Suspension
    May 2022
    Honda accord ca5 1987 ex
    Hi, im new here, i have a 1987 Accord Ex A20A2.
    I am fixing up the car, replacing every bad part, and removing rust.
    But im having some trouble finding exact oem part and replacement part.
    I need rear swaybar links arms, mine is very rusted, so I might need to weld one lookalike or is there a replacement i can use ?
    And On the rear struts there is a Coil spring insulator, with oem part number: Honda 52686-SE0-003
    Can I use KYB-SM5525?
    Im sorry i cant figure out how to post image.
    Re: Need help Accord 87 Ex Suspension
    I used adjustable integra rear sway bar endlinks. And do you really need the "Coil spring insulator" as long as its there the worst it can do is make a little bit of noise, I wouldn't hang up your project over it.
    May 2022
    No i dont actually need one, but I found several on ebay and other places.
    And i found the replacement part to the swaybar endlinks.
    But maybe i should go for the integra you mentioned.
    May 2022
    https://postimg.cc/KkLrDL32
    As i Said, i need a new insulator, my car needs it to pass control check.
    Im fixing up and removing every rusty parts.
    Most of it i can save. But some parts i must buy.
    You can't pass an inspection without it? Seriously, I don't think you will find it. The closest you might find is one for a civic/integra/crx (common platform from 88-02), I have crx front springs, so it should fit somewhat
    May 2022
    No I cant, in norway the rules are very strict.
    Cant retrofit from the civic part either? A lot of parts like this are non existent nowadays, even in the USA. Japan would be the next best place to look, but that's easier said than done.
    Did you try that KYB-SM5525 you asked about?
    LX User RI86DX's Avatar
    Jul 2022
    Rhode Island
    Quote Originally Posted by Hoonda87 View Post
    Christ, western Europe is a nanny state hellhole. Why should an almost 40 year old car that is solidly in enthusiast territory be subject to such an anal, stringent inspection?
    Well, Europe isn't nearly as car centric, and that's fantastic, but it shouldn't get in the way of people who are just into cars as a hobby. There is a way around this, surely, because old hobbyist cars still get restored and put back on the road even when not a single part has been manufactured in 40 years. In this case though, I'm at a loss. It's not a popular enough car to even find coilovers for, and it's too different to retrofit from a similar model. Idk about Norway, but I doubt you could even run ksport coilovers in Germany due to TUV.
    May 2022
    Im still waiting for that part.
    Yes norway is very anal about car control.
    I found some parts im gonna try to retrofit
    Feb 2023
    86 accord lx
    Did you ever find a good interchange/retrofit part for that spring insulator? I broke mine today.
  1. 88 accord suspension
    By 88accordaf in forum Newbie Introductions
    Last Post: 07-31-2015, 10:24 AM
  2. 89 Accord front suspension help...?
    By blackcougar141 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-17-2006, 09:21 PM
  3. civic suspension on a 3g accord???
    By Aer0deck in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-05-2006, 08:42 AM
  4. 2003 accord suspension
    By boe in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-03-2003, 10:37 AM
