Results 1 to 14 of 14
Thread: pls advice
    Mar 2023
    1987 Honda accord DX 2 Door 4spd AT
    Texas
    pls advice
    currently have an 87' accord DX that is carb'd and was wondering if there was anyone who knows someone who knows something about it... lol
    Here are the current problems
    (have gotten it to idle better, but it jumps up and down and doesn't like to idle below 1000 rpm.)
    (will die after about 5 minutes of driving, rpms will float down and lose power, try to jump back up but just cant regain power, needle will show rpm of like 3000 but the car is not receiving any power whatsoever)
    (got cylinder three back to about 160 psi, other cylinders read fine PSI)
    (loses rpms when brakes are applied)
    i would like to switch it to fuel injection but how would i start on that??? need help
    LX User RI86DX's Avatar
    Jul 2022
    Rhode Island
    Re: pls advice
    Not a good idea to make multiple threads with the same content...anyways, there's been probably 10 guys in the history of CA Accords who have successfully done carb to EFI conversions on them, it's a lengthy and complex job. Better off with a Weber carb swap.
    Re: pls advice
    To do a FI swap you really need a working FI donor car. Its not a quick fix, its a major project.
    Are you saying
    -the car dies after 5 minutes
    -you try to give it gas but you cant increase the engine speed
    -the tachometer does not correspond to the engine RPM speed?
    Does it start back up when it dies?
    Mar 2023
    Texas
    Re: pls advice
    it can start after dying, but dies again quickly.
    the Tachometer seems correct
    Re: pls advice
    IF you loose RPM when you press the brake, i would check for a vacuum leak. Check all the hoses and you can spray carb cleaner round the hoses and carb to find a leak, the RPM will change when it sucks in the carb cleaner.
    When it dies i would also confirm you are getting fuel and spark, no loose wires, etc.
    Re: pls advice
    Quote Originally Posted by RI86DX View Post
    The one that gets me is start 4 posts then dont log back in for 3 days or respond.
    Mar 2023
    Texas
    Re: pls advice
    sorry. i have 2 jobs and trying my best to make ends meet. i didnt know i came off as rude.
    Re: pls advice
    Quote Originally Posted by Brandopatt View Post
    Its not a problem. I closed those other threads so all your answers will be in one place instead of spread out. It makes it less confusing for everyone.
    Re: pls advice
    Kind of sounds like one of the hot idle circuits is opening up and leaking vacuum. If you're really trying to make ends meet the easiest thing would be to follow the vacuum delete thread, but the best thing to do is probably a Weber swap
    Mar 2023
    Texas
    Re: pls advice
    im in a much better situation now and am making money again. What im going to start with is rebuilding the carburetor with the help of an old mechanic willing to lend me a hand. there is a junkyard near me with a fuel injected LXI with only 135k on it? should i take that fuel injection system? how much do you think they would cost me
    Re: pls advice
    I think what needs rebuilt is that mess around the carb, the carb itself may need nothing more than a clean and a base gasket.
    Imo the fuel injection is just a headache. A Weber is simple and there's a bunch of threads on here.
    Jul 2022
    Rhode Island
    Re: pls advice
    Like ShiRen said...Weber swap is your best bet.
    Unless that LXI was hit by a train or a speeding semi or is a severe biohazard car it sure as hell doesn't belong in a yard with only 135k on it - what a waste. Car donation/I buy junk cars outfits are fucking scumbags....can't forget insurance companies too.
    Re: pls advice
    Eh, there's lots of reasons these cars get thrown out. Depending on the state, they may even be thrown out due to rust. But things like dead trans, carb trouble, head gasket, even a tw sensor or ignitor, they can be hard to diagnose or fix. It's a sad truth and it's very wasteful, but the majority were already taken off the road by cash for clunkers, heck, count every vehicle you see made pre 2005, the number hurts
    Jul 2022
    Rhode Island
    Re: pls advice
    I'm not sure these cars qualified for C4C - MPG might have been too good...I'm sure a few got snuck in though with how corrupt that program was.
  1. Replies: 1
    Last Post: 04-23-2018, 09:45 AM
  2. help me out pls
    By high school in forum Classic Honda Community Chat
    Last Post: 11-20-2003, 05:45 PM
  3. pls help
    By slickrick in forum 3geez Accords
    Last Post: 03-22-2003, 02:08 PM
  4. PLS NEED HELP!!!!!how much for B20A
    By od2681 in forum General Engine Swaps
    Last Post: 12-01-2002, 02:06 PM
  5. Pls help me decide
    By accordexi87 in forum Classic Honda Pics & Videos
    Last Post: 09-28-2002, 03:00 PM
VigLink badge
