Results 1 to 3 of 3
Thread: FAST IDLE VALVE 89 LXi
    Aug 2021
    1988 Accord Coupe LXI
    Does anyone know of a good part # for a Fast Idle Valve or a way to repair/rebuild them? Maybe an alternative part that will work. I have the surging issue when the engine is warm.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: FAST IDLE VALVE 89 LXi
    I don't know a lot about the fuel injected motors, but have you tried cleaning and adjusting it? And are you sure the iacv is not the culprit?
    Is this thread any help?
    https://www.3geez.com/forum/showthre...ock-off-plate)
    conozo's Avatar
    1988 Honda Accord DX, 250,000 Miles, Daily Driver
    Fort Wayne, Indiana
    When you unscrew the top cover on it with the two Phillips screws, can you use a big flathead screwdriver and screw down the plunger inside till it wont go down anymore. It doesn't take much force to screw it.
    You can take the IACV off and spray the air intake/outlet ports out with carb cleaner real good.
    Make sure your coolant is bled from any air bubbles.
    1988 Honda Accord LSDX-I
  1. Fast Idle Thermo Valve
    By tad70 in forum 3geez Accords
    Last Post: 12-12-2023, 03:10 PM
  2. fast idle valve
    By import racer in forum EFI Tech
    Last Post: 04-22-2012, 07:49 AM
  3. Fast Idle Valve
    By w261w261 in forum 3geez Accords
    Last Post: 09-25-2007, 12:48 PM
  4. removal of the fast idle valve
    Last Post: 02-03-2006, 09:11 AM
  5. HELP!!! Fast Idle valve
    By enkeisroller in forum 3geez Accords
    Last Post: 05-18-2003, 10:09 PM
Tags for this Thread
