Results 1 to 7 of 7
Thread: 2-Step button for honda accord 1988 with obd0
    Nov 2023
    Honda accord 1988 LXI
    Sweden
    Hi, i was wondering how i would go about to make a 2 step button for my accord with obd0, would i need to convert it to obd1/2? Its got a a20a3 engine.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: 2-Step button for honda accord 1988 with obd0
    No. You need a turbocharger and whole aftermarket ECU. Don't even bother looking further into this, bad idea in the first place.
    Nov 2021
    1987 Lx 5 speed carb'd
    If you look enough into msd setups, you'll be able to figure out something. I used to use the choke on the stock carb for acting like a two steup. It worked kinda but Ive switched to Weber 38 now and am planning a build with certain things and msd is where ive looked. Got a good base line idea for me. Best of luck though.
    Sent from my moto g stylus (2023) using Tapatalk
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    God... Don't use your choke like that. Msd might be able to, though you'll be a lot better off using a megajolt
    And either way, it's not two step, it's just a launch limiter
    An MSD 7 should be the answer thats what most drag racers use.
    89T's Avatar
    Apr 2004
    for pops and bangs you need obd1 to pull timing and add fuel. otherwise, it's a launch limiter.
    un-motivated!
    3GR
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    It'd probably pop and bang if you just remove the cat
  1. Replies: 6
    Last Post: 08-26-2023, 09:54 PM
  2. Step by step DIY Webber convertion + question
    By ADRIANFARINA in forum Carburetor Tech
    Last Post: 09-22-2014, 03:13 PM
  3. Step by Step SIG making in PS (as requested)
    By mkymonkey in forum Classic Honda Community Chat
    Last Post: 02-23-2010, 06:20 PM
  4. b18c step by step swap directions?
    By swell in forum General Engine Swaps
    Last Post: 12-24-2009, 07:40 AM
  5. 1988 Honda Accord LX
    By dreamracer88 in forum Classic Honda Pics & Videos
    Last Post: 04-08-2003, 07:54 PM
