Page 1 of 5 12345 LastLast
Results 1 to 25 of 109
Thread: Progress thread
    Jun 2010
    Progress thread
    Finally got around to taking a few pics.
    It's a work in progress but coming along decently.
    Not too bad for a 400$ special that barely ran.
    Yes I had to use hood risers... I know... carb breather was smacking the underside of the hood and I got those risers for dirt ass cheap. Plus the cool kids love it
    Originally posted by ShiRen:
    Aug 2017
    1987 Honda Accord LX, 2002 Subaru WRX Wagon, 1988 Volkswagen Vanagon GL, 1982 BMW 323i
    Colorado Springs
    Re: Progress thread
    Looks great! Keep the pics and updates coming.
    Re: Progress thread
    "A few" as in two???? Good grief.
    JK, looks good. What are the next steps?
    Jun 2010
    Re: Progress thread
    Had to repair the louvers so those will go on next.
    Needs wheels pretty bad >.>
    Going to get ahold of a b-series dcoe manifold and see if it can be modded like the FI intake can be. If so, it's on for a pair of 40 or 45s.
    Needs some bodywork done.
    Still on the hunt for a manual trans and all that.
    Jun 2010
    Re: Progress thread
    Louvers on! pics inc tomorrow.
    Looks like PS pump is dying. Steering is jittery and sometimes feels like no power assist at all especially when stationary. Making a good awful screech when turning too. Not a whine, literally a screech.
    Removed my carb sync rig for the cold weather. She did NOT want to start in the cold with it setup that way. Starts all good now. Choke still works when it wants to but I think the carb is just wearing out. It's a bit old and been through a few rebuilds. Is leaking a little around the throttle shafts which is typical but does show its age.
    SEi User Shane86's Avatar
    Feb 2016
    Florida
    Re: Progress thread
    Looks Cool looking forward to more updates
    Re: Progress thread
    Little plumbers putty around the ends of the carb shafts will fix that right up!
    Jun 2010
    Re: Progress thread
    Hm, never though of that... think I've got some laying around. My only worry is having to take the linkage off again and I just got the kickdown cable set perfectly. It actually shifts when it's supposed to and even downshifts now! No more slipping either!
    Jun 2010
    Re: Progress thread
    Just going to have to post links cause if I post the pics they are gigantic lol
    https://i.imgur.com/TQJqnFq.jpg
    https://i.imgur.com/lxSHDJH.jpg
    https://i.imgur.com/5HiTuRy.jpg
    Needs paint pretty bad. Going to look into rust repair when the weather warms back up.
    Linkage setup for auto trans..
    You can see where the air filter got smashed by the hood.
    https://i.imgur.com/CP4BSVM.jpg
    Engine shot just cause.
    https://i.imgur.com/MH9qDOA.jpg
    Made a short video of the steering noise..
    https://youtu.be/976nWkf_d2g
    Re: Progress thread
    You out of fluid?
    Jun 2010
    Re: Progress thread
    You out of fluid?
    Nope. It's within the min/max lines.
    Re: Progress thread
    I'd say you have a bad pump then.
    Jun 2010
    Re: Progress thread
    Would tie rod ends make noise like that if they weren't greased properly? Had new ends put on when the steering rack was replaced but dont know if the shop greased them. They are the type with a fitting on them.
    Pretty sure on pump going bad too just cause of the hard turning and it will hit hard spots. Like you're in the process of turning the wheel and it'll hit spots where it feels like it loses power and you have to muscle through it.
    Considering doing a manual conversion though... PS has been nothing but a pain in the ass.
    Pressure hose leaked bad when I got the car, replaced it. Then rack itself starts pouring fluid, replace that, then another hose starts leaking, replace that... now pump going... UGH.
    Anyway, thanks for looking.
    Re: Progress thread
    Well, the good news is that there's nothing else left to break!
    Jun 2010
    Re: Progress thread
    And we're back.. Had some family stuff to deal with so haven't been on in a while.
    On the plus side, power steering pump fixed my problems. All is good in the hood with that now.
    Also found the electrical culprit. It is in the hazard circuit. Not sure exactly where but when I unplug the hazard fuse under the hood, everything is good. Course, hazards don't work. Signals do though so whatever.
    Also backed into the wife's car so in need of a trunk lid if anyone has one😆
    Jun 2010
    Re: Progress thread
    Suspension is done... finally.
    2g Prelude front upper arms are in, adjustable arms for the rear are in, alignment has been set. I can do over 80 now without it being sketchy lol
    She rides good af.
    Jun 2010
    Re: Progress thread
    DCOE intake on the way!
    Only cost me 312$ and will be port matched and everything, even will have the proper angle for the forward lean of the engine. CAN'T WAIT!
    Re: Progress thread
    Kick ass!!!
    Jun 2010
    Re: Progress thread
    First test fit. Nothing hooked up yet, just mounted carbs to intake and put linkage together. Had to rig up a plate to mount the linkage posts on. Looks dirty but it works quite well actually.
    Slapped it on to test fitment. Intake slid on like butta and all the room in the world.
    Still have to route the old water lines, hook up fuel lines and figure out how to run the throttle cable.
    I think I may be able to run the transmission cable on the left side using the linkage there.
    Then we pray it runs
    https://imgur.com/FZebzaM
    https://imgur.com/htSWx26
    Re: Progress thread
    Dang bro. Somebody vandalized your valve cover!
    JK looks great!
    DX User DanJDT's Avatar
    Oct 2017
    1988 Honda Accord
    Re: Progress thread
    That looks freggin amazing. Keep it up.
    Jun 2010
    Re: Progress thread
    It's alive!
    After spending hours in the 90 degree sun, it runs... like shit haha. Actually does great under wot but having idle issues. I can get it stable at 1500 rpm but below that it gets shaky and pops a lot. Also drops hard when I put it in gear. Drops down to 500ish rpm. Seems odd to me that it would drop that much. Only would drop about 200rpm with the 32/36 on it.
    Any ideas there?
    Next step is tuning. Got them sync'd the best I can. Just needs to be gone through and jetted for the engine.
    But, IT'S ALIVE!
    Jun 2010
    Re: Progress thread
    The valve cover, someone here did it for me but I cannot for the life of me remember who it was lol. It came from the gold accord I had over 5 years ago. Held onto it all this time.
    Jun 2010
    Re: Progress thread
    Updated pic with everything hooked up. My linkage is ghetto as hell but it works.
    Re: Progress thread
    Looks sick!
  1. '89 Accord LX-i progress thread
    By 3geeSlagle in forum Classic Honda Pics & Videos
    Last Post: 08-04-2012, 10:02 PM
  2. frantik's suspension progress thread
    By frantik in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-23-2008, 03:45 PM
  3. Victors turbo non-progress thread
    By SQ is the SQUAD in forum Forced Induction
    Last Post: 02-17-2007, 06:35 PM
  4. The Progress Thread
    By Tomisimo in forum Classic Honda Community Chat
    Last Post: 01-26-2007, 03:14 PM
  5. Official 3G convertable progress thread
    By cvergi01 in forum Classic Honda Community Chat
    Last Post: 05-14-2005, 11:38 AM
