Results 1 to 5 of 5
Thread: Fixing shift rod bushing for firmer gear stick
    Feb 2023
    Honda accord 1988
    Post Fixing shift rod bushing for firmer gear stick
    Here is how i fixed the bushing
    First i had to get the bushing out, so i took out the "SHIFT ROD CLEVIS BOLT" as per the manual, i took it out by connecting a few extensions and reaching to the bolt from behind the engine.
    After taking it out i noticed the lower cap was missing and there was a tear in the bushing where the cap was missing, i also noticed someone had used electrical tape in an attempt to make it wiggle less.
    Then i covered the whole thing with silicone, i believe using windshield sealer is better but i did not have any, i also covered where the bushing sets with silicone and then put the bushing
    back in its place.
    I put the bolt back and tightened it just a little bit, and then left the car in neutral (just so that the bolt is centered as much as possible) and left it to dry, and after drying i tightened the bolt to specs.
    Re: Fixing shift rod bushing for firmer gear stick
    Thats not a bad fix. The loose shifter is annoying to drive.
    I made one out of nylon but I think Cheddar makes them from time to time.
    The big bushing on the torque rod is a civic/crx bushing you can buy in poly. It helps too esp. since you got a trans leak out of the shift seal.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Interesting. I have poly bushings and a delrin bird cage bushing, but I've never looked at that one. Mine is pretty tight, but I'm curious if there is any play in that
    Looks like you really need a new shifter seal though :/ that's not an easy one
    Feb 2023
    Honda accord 1988
    Almost every seal is leaking down there
    conozo's Avatar
    1988 Honda Accord DX, 250,000 Miles, Daily Driver
    Fort Wayne, Indiana
    Cheddas makes a delrin kit for our cars. I think it includes everything including the part you fixed but you may want to ask first before purchasing because i cant remember.
    https://www.cheddasauto.com/product-...ransmissions-2
    1988 Honda Accord LSDX-I
  1. Torque Rod bushing replacement
    By Whistler225 in forum 3geez Accords
    Last Post: 05-12-2006, 02:55 AM
  2. Need to shorten shift stick about 2.25"
    By FyreDaug in forum Classic Honda Community Chat
    Last Post: 03-29-2005, 01:13 PM
  3. replace radius rod bushing?
    By rdn in forum 3geez Accords
    Last Post: 06-24-2004, 05:25 AM
  4. SHift Stick Keeps Poppin Out Of 5th :( (HELP!!))
    By SadDX in forum 3geez Accords
    Last Post: 01-12-2004, 08:58 PM
  5. Auto shift stick appearance.
    By Defiant[YD] in forum Interior & Exterior Care
    Last Post: 06-26-2003, 08:49 AM
