Results 1 to 9 of 9
Thread: 87 LXI questions
    Apr 2024
    87 Honda lxi
    87 LXI questions
    So I got an 87lxi A20A3 I changed out the head cylinder on it. Put everything back together and now It starts up idle is smooth but it’s really sluggish in first gear. When I rev the engine to 3000 RPMs the PGM-FI comes on the engine starts shaking the light will blink a couple of times then go away. When I drive it and come to complete stop the car will just shut off. I’ve changed out all the gaskets and Orings that are required for the head change, valves are adjusted to spec from the service manual, timing is set as well.
    Apr 2024
    87 Honda lxi
    Re: 87 LXI questions
    Sorry I accidentally hit create.
    It’s has a new distributor and cap and rotor. New fuel pump
    My questions are can i delete the egr valve?
    Is it possible to delete the black vacuum box? I’ve seen that you can do it the carb version but not much information on the fuel injection.
    If I change out the fuel filter will that fix my problems?
    Quote Originally Posted by Salehwater View Post
    Right now. I would check the timing belt is on correct and not a tooth or more off.
    LX User Jinnai's Avatar
    Jul 2020
    Colorado Springs
    Did it work before you changed the head, or how different is this problem from the one it had before you did that? Is the fact that it dies when you come to a stop related to temperature?
    conozo's Avatar
    Fort Wayne, Indiana
    You need to count the blinks on the PGM-FI light under the seat and see what it thinks is wrong. It could be as simple as a wire not firmly connected in the engine bay.
    1988 Honda Accord LSDX-I
    Apr 2024
    87 Honda lxi
    The car worked up until the timing belt gave out and bent the valves on the old head. Looked over the belt yesterday and it’s on correctly and is on tight enough. The ecu under the driver seat doesn’t give out any blinks.
    Apr 2024
    87 Honda lxi
    It will still stall out if it’s at operating temp as well.
    Apr 2024
    87 Honda lxi
    A bit more information for yall I did a smoke and vacuum test. Only leaks from the smoke test were a couple Orings and clamps changed them out did the smoke test again no leaks. For the vacuum test The only line that didn’t have only vacuum was line 12.
    conozo's Avatar
    Fort Wayne, Indiana
    Do you have all the air out of the coolant system? Having air in the coolant can cause the car to stall during idle.
  1. Questions about my 86 Accord Lxi hatch
    By Shawn Silva in forum 3geez Accords
    Last Post: 07-17-2018, 08:11 PM
  2. 1986 Lxi Oil Pan Questions
    By Anchovius in forum 3geez Accords
    Last Post: 12-23-2017, 07:59 PM
  3. 87 LXi transmission questions
    By Roofy in forum 3geez Accords
    Last Post: 06-20-2010, 09:48 AM
  4. Installing this alarm and power door on 88 LXi (questions)
    By AQcz in forum Interior & Exterior Care
    Last Post: 04-09-2004, 12:07 AM
  5. 87 lxi questions need help
    By 87 blue demon in forum General Engine Swaps
    Last Post: 09-22-2003, 07:54 PM
