Results 1 to 3 of 3
Thread: Pcv black box hose
    Mar 2024
    88 accord dx
    Pcv black box hose
    88 accord dx just made it over 500k miles. Had all the coolant lines rust out on my on the intake. Finally pulled it all off plugged all the coolant lines going to the intake and put it back together. The mustard of it is the weird “s” shaped hose that goes into the breather box by the oil filter broke off. My question is can I just thug it out without it? If it’s stinky or smokes I don’t care I just want to keep my hondeezy alive without pulling my intake back off. Any tips are appreciated
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: Pcv black box hose
    The intake side needs to be plugged. Put a filter on the valve cover and the black box. You can't drive if there is a vacuum leak, but the actual crankcase vents are fine going to atmosphere, but I got an oil analysis before I put a filter on the black box and there was more ring material in the oil than I'd like, so you should really make sure it's filtered. No unfiltered air should be going in the engine
    Mar 2024
    88 accord dx
    10/4 thank you
  1. Replies: 15
    Last Post: 05-29-2019, 06:05 PM
  2. Replies: 34
    Last Post: 05-02-2017, 06:43 PM
  3. PCV Crankcase Hose
    By firefighterwhite89 in forum EFI Tech
    Last Post: 07-28-2013, 02:13 AM
  4. pcv valve hose question
    By nail4545 in forum EFI Tech
    Last Post: 07-21-2010, 02:15 PM
  5. PCV and black box thing
    By sccrsteve5 in forum Classic Honda Community Chat
    Last Post: 01-12-2004, 12:54 AM
Tags for this Thread
