Results 1 to 2 of 2
Thread: Wont idle after vac delete
    Mar 2024
    88 accord dx
    88dx just vacuum deleted the black box and most other lines. Also deleted most coolant lines to the intake since they rusted out on my car. Car won’t run unless I keep my feet on the gas. I’m assuming a vacuum leake somewhere but how can I check if I can’t keep it running long enough to spray it with brake cleaner to hear if the idle changes. Anyone else have this issue if so how did you fix? I’ve turned the fuel mixture screw all the way out and followed the vac delete guide with no success.
    Re: Wont idle after vac delete
    Try a new carb base gasket
  1. Delete or not to delete the EGR sys.
    By firefighterwhite89 in forum Restoration & Custom Fabrication
    Last Post: 02-16-2011, 01:33 PM
  2. Replies: 9
    Last Post: 03-13-2004, 01:45 PM
  3. Jacked Up Idle After Vac Line Non-Removal
    By SteveDX89 in forum Carburetor Tech
    Last Post: 12-30-2003, 02:52 PM
  4. please delete
    By carlessNcareless in forum Classic Honda Pics & Videos
    Last Post: 12-05-2002, 06:36 AM
Tags for this Thread
