Results 1 to 2 of 2
Thread: 85 accord weber problems
    Jul 2024
    1985 honda accord
    Hey I'm super new to the forums, I just picked up an 85 Lx 3 weeks ago and just got my weber carb delivered the other day. So far I have the old carb off and the weber on, fuel line hooked up, fuel return line plugged, throttle cable finished, but I'm running into an issue because I was dumb and didn't label ANY lines before I started disconnecting them. From my knowledge (and it's not a lot) I only need to hookup the distributor vacuum line to the front of the weber? Also now that i have a BUNCH of lines open, also to my knowledge I need to plug up every single one? Moral of this sad sad story is I messed up and I wanna borrow some knowledge from yall on everything I should do to make sure my new weber carb works!
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: 85 accord weber problems
    You should only have a few lines. One from the dizzy to the carb, tee that to the manifold. And your brake booster and pcv. I don't know if there is any separate systems on the 2g that run on vacuum, but I'd think that'd be apparent once you start removing everything else
  1. 32/36 Weber in my '87 Accord
    By Square_Bear in forum Carburetor Tech
    Last Post: 06-06-2018, 06:31 PM
  2. 89 Accord Weber 32/36
    By inman in forum 3geez Accords
    Last Post: 05-19-2017, 06:44 PM
  3. Weber jetting problems
    By Ajamben in forum Carburetor Tech
    Last Post: 03-05-2016, 04:13 PM
  4. 77 Accord update - Weber!
    By bluesky6 in forum 1geez Tech & Performance
    Last Post: 12-21-2011, 04:26 AM
  5. Weber conversion problems
    By RatRod in forum Carburetor Tech
    Last Post: 11-29-2009, 05:12 PM
