A little bit ago I had a fuel leak on my car, specifically it was that fuel leaked through the firewall port right next to the secondary fuel filter. This fuel made its way into the cabin and drenched basically everything in fuel in that quadrant of the inside. Right when I was pulling back into home, the tachometer shut off, signals stopped working, and the coolant gauge went kaput, but the engine kept running and the speedometer still worked. Along with that, the battery light still functions properly. I have since fixed the fuel leak and cleaned/dried everything I could see.
Another thing to note, the car doesn’t register turning the key into the third position, just before cranking the car. It seems to only work in the first and second positions properly.
The car ran great aside from the tach and coolant gauges not functioning, until today. I started it just fine and it idled for about 2 minutes, then died on me. I have a pressure gauge on my fuel line that reads no pressure when the car is on. I have tried turning the key back and forth and still no fuel pressure. I have tried resoldering the joints on the grey fuel pump relay on the backside of the interior fuse box. As far as I am aware, I don’t have that small black fuel pump relay mounted on the left hand side to the right under the steering wheel. For reference, I have an ‘89 LX sedan with a weber swap.
I thought my ECU was bad or i shorted something out, but upon a visual inspection there are no blown diodes, capacitors, or resistors.. everything (visually) appears intact.
