Results 1 to 4 of 4
Thread: 1988 Honda Accord burning oil only when fully warm
    Aug 2024
    1988 Honda Accord
    Gresham, Oregon
    Hey all! I recently picked up a 1988 Honda Accord and have been slowly working out the kinks. I recently did a compression test which tested each cylinder at 157-161 psi of compression. yet when fully warm, the car puffs lots of blue smoke out of the tailpipe. Like a lot of smoke. It currently doesn't have a catalytic converter on it, but this is a lot of smoke for that type of issue. What could be other causes of this issue? I also did a headgasket test which said there was no headgasket leak. Thanks!
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Re: 1988 Honda Accord burning oil only when fully warm
    Valve seals, though I still wouldn't rule out the rings
    Aug 2024
    1988 Honda Accord
    Gresham, Oregon
    It still could be the rings? I'm likely going to do a full head job on it, but I really don't want to do rings and a new hone. I thought that with that good of compression the rings would be good? I thought maybe they could be sticking, and hopefully a top end cleaner like seafoam could help? I can't afford anything more than a head rebuild unfortunately.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Yes. Compression rings don't stop oil from getting in the combustion chamber, the oil rings do. Plus I imagine there is still some degree of blow by.
    I would try some like a tablespoon or two of marvel mystery oil down the spark plug holes and letting it sit for at least 12 hours
    A valve stem seal job or a ring job are both going to be pretty cheap if you do it yourself
  1. Honda settles class-action lawsuit over oil-burning V6s
    By 87accordlxi in forum Classic Honda Community Chat
    Last Post: 10-24-2013, 02:02 AM
  2. 1988 Accord DX stalls during warm up, then no start
    By john doh in forum Carburetor Tech
    Last Post: 04-05-2011, 07:39 AM
  3. Burning OIL
    By perlov in forum EFI Tech
    Last Post: 08-01-2007, 03:09 AM
  4. Burning oil
    By ahmad89 in forum 3geez Accords
    Last Post: 04-22-2007, 08:17 AM
  5. burning oil
    By ace69247no13 in forum 3geez Accords
    Last Post: 06-24-2005, 12:28 PM
