Results 1 to 8 of 8
Thread: Remove Cat installed Test pipe - CEL on, as expected
    Dec 2013
    1989 Honda Accord Lxi 2 Door Coupe; 1989 Prelude 2.0si
    Seattle, Wa
    I did this a while ago on my 89 Prelude. Removed Cat convertor, installed test pipe. Check engine light came on after about 5 miles later, came on every time the engine warmed up. I disconnected the battery to drain the ECU, did my due wait, reconnected & it hasnt returned since.
    Same scenario with the Accord, but the CEL comes on even after pulling power to the ECU. Engine runs just fine no issues, but Im wondering if Im going to have to hook a O2 sensor to the Test pipe & wire it in to resolve the light issue.
    Question do I just splice it into 1 of the sensors on the exhaust? If so does it matter which one?
    Thanks
    Re: Remove Cat installed Test pipe - CEL on, as expected
    I would check the code.
    There is no 2nd O2 sensor after the cat on these cars.
    Dec 2013
    Seattle, Wa
    Yeah, I didnt think so
    Code 12 Exhaust Gas Recirculation System??
    Wooo Boy! Read several threads in the EGR valve...... Car runs just fine. Idles fine, gas mileage it fine, just the CEL light is on all the time
    Ill check the EGR valve, this may be just a coincidence, but my Prelude did the exact same thing when I went test pipe, & disconnecting the battery for 20 seconds & resetting the ECU cured it & it hasnt come back. The Accord is being more persistent.
    Quote Originally Posted by Blainethemono View Post
    Yeah the EGR code can be a PIA to get straitened out.
    Dec 2013
    Seattle, Wa
    Well, it appears the yellow wire comes straight from the interior fuse box to the CEL with a single connecter between them.
    ShiRen's Avatar
    May 2018
    87 Accord DX
    MO
    Yeah? What did you expect there? The ECU turned the light on.
    Dec 2013
    Seattle, Wa
    If I traced my wires correctly if I remove this fuse, the CEL goes out, but the ECU will still flash codes
Name:	Internal Fuse box1.jpg
    Dec 2013
    Seattle, Wa
    Yes, thats what Im trying to achieve. Disable the light only. Car runs fine.... I guess I could just put a black piece of tape over it lol
    Wiring diagram shows that the yellow wire only powers the CEL, & NOTHING else.
  1. Straight Pipe ? test pipe VS high flow cat
    By Acid X in forum Performance
    Last Post: 07-10-2006, 11:41 AM
  2. test pipe to replace cat
    By jlaccord89lxi in forum Classic Honda Community Chat
    Last Post: 07-27-2003, 03:46 PM
  3. CAT vs. TEST PIPE??
    By krott5333 in forum Performance
    Last Post: 06-15-2003, 06:10 PM
  4. test pipe
    By Experimental_Honda in forum Performance
    Last Post: 06-03-2003, 05:46 AM
  5. INFO NEEDED: test pipe for cat converter?
    By tea102 in forum Performance
    Last Post: 07-18-2002, 07:39 PM
