Results 1 to 11 of 11
Thread: 1983 Accord LX Hatchback?? Rebuilding motor
    Oct 2024
    US
    Good afternoon,
    Thanks for the acceptance into your great wealth of knowledge. Located in North Idaho and just bought a 1983 Accord LX HB with a Frankenstein motor. Block is an EK1 (3631908) 1.8L (not the original block, serial number shown on tag not the same serial# stamped into the block), transmission is a GK coded 5 speed (doubt it is original), and the head is an unknown (wish I knew if serial numbers were stamped for reference, there is PB2-4 shown??). I am in the process of rebuilding from the ground up but am having issues finding a correct head gasket and intake/exhaust gasket. I just ordered a kit from RockAuto for motor gasket set, hopefully head gasket fits (APEX AFS1006), clutch kit (MU476151). If anyone has better info on head gaskets, please chime in.
    I will also be removing vacuum lines and carb, swapping to a Weber eventually. I have seen numerous threads covering that one here but if anybody has any Gotchas they may want to share, please do.
    Re: 1983 Accord LX Hatchback?? Rebuilding motor
    Welcome to the forums.
    Hope you get it figured out.
    Oct 2024
    US
    Me too! Parts are on the way so we will see.
    Oct 2024
    US
    Sorry I haven't updated this but times are tough. Motor is in, it turned out to be from an 80-81 Prelude. Weber carb is on, new fuel pump, etc. My issue now is that for some reason I have lost power to the fuel pump. I have power at the fuse but nothing at the pump connections. I tested the pump with alligator clips and a battery, works fine. The wire is a Black/yellow stripe at the pump (power) black (grd). Looking at the skematic (I am now expert, believe me) they show a black w/yellow st and a white w/blue st going to a fuel cut-off relay on the carb, is that where the fuel cut -off relay is? The motor will run, I just have no fuel. Any thoughts on bypassing and connecting the FP to a switch? Click image for larger version.
ID:	11395Click image for larger version.
ID:	11396Click image for larger version.
ID:	11397Click image for larger version.
ID:	11398 In the picture with the big red plug, I have power at that BLK/Y wire. I also have power at the blk/y wire (pic of wires in engine bay) which is where I thought I got power for the choke (Weber single wire choke) but what would complete the circuit for the fuel cut-off relay if nothing connects the w/bl wire shown on the carb?
    Have you located and tested the cutoff relay?
    He started a new thread in the 2 g section before I moved it Snooz.
    Oct 2024
    US
    I have not.
    Oct 2024
    US
    I have pretty much removed unplugged everything from the front of the fuse panel but have not unplugged anything from the back, just kind of hanging there. I am looking to see if I can locate another relay tucked up in there somewhere, not looking good though. According to the manual I have, the fuel shut off relay should have 2- blk/y wires, one red/y, and one black. Durned if I can find it.
    I only know the 3 g but I think the 3g one is on the back of the fuse box on carb models.
    Oct 2024
    US
    I believe you are correct, at least that what the back of the fuse panel says. Well, here is what I found out today. Gotta love a multimeter. I have traced wires from the pump to the corresponding plug in points, along with some other wires. I have 3-5ohms across all wires. Coming from the pump are two wires, one blk/y stripe and a black w/brn spots. The blk/y wire plugs directly into the back of the fuse panel where I have pictured. The ground plugs into the relay that is pictured and lined in black, labeled ground. Along with the relay connections, I have a wht/blue wire (shown on pic as wht/bl st) that terminates next to the blk/y wire under the hood that I have already attached a pic for (no idea what it is). I have also tested ohms across the relay (labeled on fuse panel as fuel cut off) and am hitting around 180+Ohms across a couple of the connections which seems real high, since others are reading around 10.5ohms. I wish I knew how to test these relays while they are out.
ID:	11409Click image for larger version.
ID:	11410Click image for larger version.
    Id put the choke wire someplace else besides on that relay.
  1. Hi all! Owner of an EUDM 1983 Accord hatchback
    By wendigov in forum Newbie Introductions
    Last Post: 06-02-2020, 06:52 AM
  2. 1983 Accord Hatchback - Newbie needs help with the carburetor!
    By Saavedro88 in forum Newbie Introductions
    Last Post: 02-09-2015, 12:54 AM
  3. I need a 1983 Accord Hatchback dash
    By tumminello123 in forum 2geez Accords
    Last Post: 03-04-2010, 03:32 PM
  4. 1983 Honda Accord Hatchback Dash
    By tumminello123 in forum Wanted
    Last Post: 03-03-2010, 05:34 PM
  5. 1983 honda accord hatchback in New Jersey
    By the fat bastid in forum 2geez Accords
    Last Post: 11-05-2009, 09:41 AM
