Results 1 to 5 of 5
Thread: where to start?
    Mar 2003
    1988 honda accord lx
    dallas
    where to start?
    ok i dug up the info the PHAT guy from the import shop gave me..
    know problems at a simi test not all probls posibly
    distributer seal
    oil pan gasket leak
    exhaust leak
    power stearing pump leak
    carburator (just said i needed a new one)
    i think thats pretty much all he told me
    SO.... best course of action.. pull the engine and get dr jeckle on it and finally find out what a car really is ( cuz i have no idea about machanics but i can learn) or just pin point and try to target the troubled areas and try to fix those... or "DUDE YOUR CAR IS FUXORED"... or ya know a b16 would fit in that...
    leme know what you guys think, its starting to warm up here in texas and i do have a set of wrenches. and its not like the car is running now anyways.. so i figure i would just dive rite in..
    well it runs but not well and not for long periods of time.
    but i dont plan on trying to trouble shoot seeing how my knowing of this is so limited
    Xeno
    Oct 2001
    87 Accord EX , 5spd , Manual
    so you are asking what to fix first !?
    if so
    oil pan gasket , dist. seal , carb ( you could get a weber ) , Power steering , exhaust !
    MIKE
    Mar 2003
    dallas
    should i totally rebuid the motor? do those sympoms reflect more problems and it would be a good idea to just total rebuild,
    or do you think its probly not that bad and i should just work on what i know and try not to mess up to much of the other things in the car.
    or it would be more cost effective to just get a new motor..
    thats what i was wondering
    Xeno
    a pile of lawn ornaments
    Newtown, CT
    well, like Mike said, just fix the things in the order that he listed, or similar and you should be back in business.
    One question though.. ..how much $$ are you willing to invest into this car, and how long do you intend to keep it? Those answers will be the deciding factor here.
    If you want a good running car with the least expenses incured, just fix what's wrong.
    The oil pan gasket is real cheap and is only about a 2hr. job. The distributor seal is really only about a 30 min. job, and the carb, well, that's a litte more involved, but still only a 1day operation. As for the ps. pump, that's also, as with all other 'problems' a very easily accessible replacement that should not take long.
    Exhaust, real cheap just get it patched, or instead of getting a new oem replacement exhaust (if it needs replacing all together), just talk to the local kid at Monroe Muffler or the equivelant and toss him $75-100 to custom bend a 2.25" exhaust for you. All you'll have to do is buy a good muffler for him to weld onto it, and you've not only got yourself a new exhaust, but a few extra hp to boot.
    At this point, there's really no need to do a complete rebuild IMO.
    -Mark D.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    definetly get a weber if your car wont even start and you have to get a new carb.. it will add HP and give you no troubles like the HONDA carb... and its cheap too... 360 bucks.. you can install it inlike 3 hours.. or less
    Travis
  1. hot car won't start
    By snoopyloopy in forum EFI Tech
    Last Post: 02-23-2010, 09:37 PM
  3. Won't Start...
    By pthump in forum Carburetor Tech
    Last Post: 05-28-2004, 05:03 PM
  4. Replies: 4
    Last Post: 12-30-2003, 10:45 AM
  5. Won't Start
    By infecto in forum 3geez Accords
    Last Post: 04-25-2003, 11:53 PM
