Results 1 to 4 of 4
Thread: Turn signal going nuts
    Scorpion88LX's Avatar
    Oct 2002
    88lx,5speed
    winston-salem, North Carolina student at Oklahoma State
    My left turn signal is going crazy it arrow is blinking realy fast. I did a search and some one said is could be the relay or the switch. However there's didn't seem to be exactly like my problem. When I got out of my car ( in a parking lot) i checked it with the turn signal on and NONE of the lights came on, on that side, but the lights on the right side still work and the head lights still work. Also today is the first time is ever did this in my car, yesterday ikst was fine. Thanks.
    Ryan
    LX User mindlos's Avatar
    97 Prelude Base
    Minneapolis, MN
    Thats what it does when one or more bulbs are out just to let you know. Replace the bulbs on the non-functional ones and everything should be good.
    Oct 2002
    88lx,5speed
    the thing is that none of the left (driver) side turn signals come on so it is hard to tell which ones are none functioning
    Ryan
    97 Prelude Base
    Minneapolis, MN
    Check your fuses then check your all your bulbs if necessary. What happens when you turn on emergency flashing? Does the driver side still not turn on? If fuses and bulbs are good you may have a broken wire.
  1. Turn Signal
    By Xaisk in forum 3geez Accords
    Last Post: 09-10-2010, 12:25 PM
  2. turn signal help
    By 1987AccordLx-i in forum 3geez Accords
    Last Post: 10-01-2008, 12:59 PM
  3. turn signal covers oem
    By xvok in forum 2geez Accords
    Last Post: 08-03-2007, 11:33 PM
  4. new ideas for turn signal
    Last Post: 08-04-2005, 04:13 PM
  5. Turn signal replacement
    By bugzboy85 in forum 3geez Accords
    Last Post: 03-12-2004, 12:37 PM
