Results 1 to 7 of 7
Thread: JDM B20A Ignition wiring.
    Jan 2003
    85 Prelude & 03 RSX- TyoeS
    Ontario, Canada
    Lightbulb JDM B20A Ignition wiring.
    Hi guys,
    I'm not on this site too often, but thought i'll pass on a tip you might like. As you may know, the JDM ignition system is a little different to what we have here. In the sense that we have an ignitor on the distrubutor and not on the fire wall. Here is what to do when you install this JDM motor in your USDM 3gAccord or 2gLude. Scrap the jdm distributor and cam angle sensor.
    get the distruibutor and cam angle sensor off of a usdm 87-88
    Integra (your better off to stick with the 87, cause i think halfway through 88 they made some revisions to electrical system). All you have to do is plug and play. That how mine is setup and it works great. Oh yeah, use your O.E wiring harness, as long as it was from a fi car.
    btw there seem to be quite a few of you doing this swap and i know what you mean when i hear complaints about finding parts. What are you guys using for replacement altenators, i think the 1990 Civic 1.6L altenator is very close.
    Would anyone be interested in Delrin bushings for the Front Suspension?? Delrin is simmilar to Polyurethane ,but has better properties.
    -SEAN
    carotman's Avatar
    Montreal South Shore
    I would like bushings
    I need these parts!
    LX User AccordSi's Avatar
    1988 Honda Accord EX (B20A)
    Caribbean
    I am very interested in the bushings. Please reply.
    1988HondaAccord | JDMB20A | JDM-CTRPistons | 11:1CompressionRatio | 7400MSDChip | 280/280CrowerCams | DualWeber45DCOE | Port&PolishedHead | OBXCamGears | OBXUnderdrivePulley | CustomOilCatch | CustomColdAir | K&NFilter | HolleyFuelPressureRegulator | CraneCamsXR700 | MSD6AL | MSDBlasterSSCoil(E-Core) | MSDSuperConductorPlugWires | ACTHeavyDutyClutch | ACT6PuckCopperDisc | JDMPreludeTypeSHeader | 63mmCustomFitExhaust | TanabeHyperMedallion | GroundControlCoilOvers | KoniAdjustableShocks | PreludeVtecBrakeUpgrade | SpecialtyProductsCamberKit | 15"MugenRnRWheels(10.5lbs) | 195/55BridgestoneGridIITires | AutometerDualGaugePod | AutometerAir/FuelGauge | VDOVacuumGauge | VDOFuelPressureGauge(inline)
    goldyaccord's Avatar
    Ford work Van
    Tigard, Oregon
    Re: JDM B20A Ignition wiring.
    -SEAN
    I think he meant that you could use Delrin as in to make custome bushings?
    reason I said that was becuase I did a search on Delrin and Came up with alot of topics with Mustang aftermarket bushings and mostly AUDI and BMW related bushings. Also, got numerous topics on explaining the properties..(Engineer talk). That was about it. They seem to have alot of them overseas. Germany, UK.
    I'll try to do some more research.
    sorry guys v8's rule
    Jan 2003
    Ontario, Canada
    Thumbs up THE BUSHINGS
    No No, I meant what I said. I just thought that if there was enough interest, I would consider custom making some more Delrin Suspension bushings. I'm sure you all know that there arn't any aftermarket bushings available for this model. I've got a set for my car (85 lude), and am just going through the finial stages on a set for the front control arms. I can get a couple of pics of them just so you know i'm not smoking sumpthin. For now the fronts will be available and in the future I know I'll be making bushings for the rear of my car and can also do the same for the Accord. That's all, so just let me know. One last thing; all the critical dimensions are acurate to within +/- 0.1mm
    Ya ya, I know I should be posting this in the "Suspension Forum". Next time.
    Ford work Van
    Tigard, Oregon
    Great!
    Jan 2003
    Ontario, Canada
    Lightbulb another thing...
    I forgot that they came out in '86, so I belive the 86 integra distributor and Cam angle sensor will also work.
  1. MSD Ignition Box Wiring Diagram
    By senor honda in forum 3geez Accords
    Last Post: 01-21-2020, 08:15 PM
  2. B20A ignition leads
    By rjudgey in forum Performance
    Last Post: 05-31-2012, 11:13 PM
  3. B20A Ignition Leads
    Last Post: 09-19-2006, 07:49 AM
  4. Replies: 6
    Last Post: 07-31-2006, 02:13 AM
  5. [Engine & Transmission] Igniton FAQ / Sparkplugs / Ignition Control Box Wiring.
    By A20A1 in forum Frequently Asked Questions
    Last Post: 08-12-2004, 11:26 PM
