Results 1 to 16 of 16
Thread: Wierd Problems
    DX User rgbpmp's Avatar
    1988 Honda Accord Lxi Sedan
    Wierd Problems
    Alright im having a few wierd problems.
    I turn on my car and it idles fine, but when i put the car in drive the cars idle falls around 700 rpm's.
    When i am driving the car with my radio on, and i turn on the blower for heater or a/c the radio shuts off and blower doesnt turn on.
    The ecu is not blinking any codes.
    I replaced the alternator yesterday. And still the same problems.
    Sometimes the car almost dies out because the idle falls so low. The battery is from autozone and is not close to a year old.
    I have no idea what the problem is.
    Could it be the battery?
    It's sounding to me like it could possibly be a loose connection somewhere. If it is, it's probably going to be pretty tough to find. Your idle might be set too low also.
    Your site is really cool!
    OldSchoolSwap's Avatar
    88 Hybrid Accord LX-i
    Miami, Florida
    Sounds like an electrical issue. Check your fuses. Loose or cut wires under the dash. Look for riggs under your dash. Old alarms or existing ones.
    Check your vacumm hoses in the engine bay. Electrical wires in engine bay.
    If all esle fails. Take it in for service.
    http://vtecnos.tripod.com
    Member Since 7-9-01
    I just had the battery checked - Good.
    I dont know what the heck the problem is.
    I know the idle cant be set too low, cause i had to raise it about 2 months ago cause it was doing the same thing. Idles fine in park or neutral, but when its in drive the car idles like crap.
    All fuses are good.
    For the electrical issue, I would get on your back and check all the wires under your dash and make sure they are connected tightly and nothing is loose or corroded etc. If that checks out ok, make sure your wires are the correct ones connected to your radio, if it was recently put in. Even if it wasnt recently put in, check them unless it is the stock deck.
    SEi User
    1994 accord coupe RIP/ 88 accord lx sedan, 99 Honda Prelude
    massachusetts
    my car does the same thing. but it never realy idles any ways. and when the base hits all the lights dim.
    one of my 88 lx's is up for parts. good engine and transmission. pretty much everything is there. the fenders and hood are bad but other than that it's pretty good.
    RIP my beutiful 5g coupe. May the villans rot in hell!
    Oct 2001
    87 Accord EX , 5spd , Manual
    for the idle thing check the PCV valve and vacuum leaks ( easy on an EFI ) !
    MIKE
    shepherd79's Avatar
    Falling Waters, WV USA
    sounds like you have electrical problems. clean your battery connections. check your ground wire to make sure it is tight.
    check your fuses, make sure they are the same Amps as it says on the stickers and not lower.
    oh yeah, take your car to autozone to check alternator too.
    I agree, check yourground wire. My friends 91 Accord had similar problems when his ground wire came loose behind his deck.
    LXi User 89AccordLXI666's Avatar
    1989/Honda/Accord SE-i FI 5speed Coupe
    Hudson Mass
    I had the same problem it turned out to be the ignition, try wiggling the key a bit before you start it and it should work... I bet that's the problem cuz I had the same shit happen to me too bro... also check your starter as well there could be a lose connection with the connecter, try fiddling with that too... hope that helps and hope ypur problem goes away and everything works fine... I'm pretty sure it's your igintion, try it out see what happens... n good luck bro... Lataz
    I will alwayz drive my 3rd gen Accord, ya'll will neva c me driving a 4 door Ford.. lol
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    i agree with oldschoolswap as far as electrical problem goes....as for your idle,...when did you last have a full tune-up?(...plugs,leads, etc.......)
    Nov 2002
    Ridin Dirty in New York
    Dude check your ground straps in your engine compartment, its probably ground related.
    Or behind the deck if recently installed.
    I last did a tune up probably 4 months ago, plugs wires, about 6 months ago i did distributor cap and rotor. I do regular oil changes.
    I took a look at the ground wire in the engine compartment and it looked fine, might need a little cleaning but looks pretty good.
    I replaced my deck over a year ago and it has been fine so far up until the problem (few months).
    But i am going to check the wires behind the dash to see about the blower motor.
    Ill check the other things too.
    Thanks, so far!
    Ryan
    I would check your deck anyway if everything else checks out good. Things can come loose!
  1. wierd
    By Warren 88 Accord in forum 3geez Accords
    Last Post: 09-14-2011, 12:08 AM
  2. 89 lxi with some wierd idle problems
    By tysn in forum 3geez Accords
    Last Post: 07-01-2006, 05:59 PM
  3. brakes....wierd...just plain wierd....
    By Microstreak in forum 3geez Accords
    Last Post: 03-27-2003, 01:14 PM
  4. Really Wierd
    By Thorny88Lx in forum Interior & Exterior Care
    Last Post: 11-08-2002, 09:44 PM
