Results 1 to 10 of 10
Thread: headlights only work on high-beam
    Oct 2002
    1987 accord lx
    Chicago
    Hey guys,
    I'm being a little lazy here by not looking through the schematics to think about this more, but I've been really busy...
    Anyway, the headlights on my g/f's 86 lxi go out sometimes. Then they don't come on if you switch the lights off and on. They DO come on if you put on the high-beams. Then the normal lights come on. If you pull the high beam switch again you get the high-beams, and then if you pull it again it goes back to regular lights.
    But after maybe 10 minutes they'll just go out.
    I'm not sure if the hi-beam trick always works. But I'm gonna get off my ass to fix it.
    Is there just a relay that is going bad? If so, anyone know where this relay is? Is it in the fuse-box under the hood?
    You think I could just re-solder the relay and it would be all better, or should I get a new relay. I'm trying to be cheap with my car repairs.
    We're just finally starting to get warm weather here in Chicago. But then it's supposed to rain like every day this week...
    Oct 2002
    1987 accord lx
    Chicago
    Also, if it is a relay, does anyone know the procedure for testing this particular relay with a multi-meter or a test-light probe?
    I'm thinking your headlight combo switch may be bad, in which case I would just get a new one and be done with it. Your headlight wire for normal lights could be snapped on both sides, it's pretty common, but that would be very coincidental if both sides happened at once. But you say they come on when you put your high beams on so that's probably not the problem.
    Jul 2002
    89 Accord LX-i coupe, Auto
    Missouri
    mine are the exact opposite. just last week my high beams started going out, then i would jiggle the switch and they would come on, but now they dont come on at all. ur problem, along w/ mine, is more than likely just a faulty switch.
    "Turn off the television sets and eradicate the slander that says a black youth with a book is acting white." - Barack Obama
    If you jiggle the switch and the lights flicker and shit, your switch is faulty. If it doesnt, it could be something else.
    2.0Si User Grant2k's Avatar
    Jul 2002
    where the headlights hinge up and down the wire probably broke. this happened to mine. they are still in the wire loom from the factory so they wires touch sometimes and sometimes don't. at any auto parts store you can get a socket for a 2 headlight system with about a foot of wire at the end of it. take out your headlight and reach your hand in as far as you can and cut the wires and splice in the new ones. just tape up the splice real good. it's easy. it may not be that but that's an idea.
    I dont think so because they work. It's the switch. If they didnt work, then you're probably right.
    Oct 2001
    87 Accord EX , 5spd , Manual
    well check out this thread !
    i posted pages from the service manual there about wiring and trouble shooting of retractor lights !
    MIKE
    Oct 2001
    damn i forgot to post the link ! here it is !
    https://www.3geez.com/showthread.php?...453#post166453
    MIKE
    Oct 2002
    1987 accord lx
    Chicago
    thanks!
    Hey guys,
    Thanks a lot. I think this is good advice. It could be the switch, but I see how it could be the wires in the loom too if the insulation has come apart and sometimes the current goes to ground yet sometimes doesn't.
    ALTHOUGH, if this was the case, then they would be intermittent, but messing with the switch wouldn't fix the problem.
    So because it fixes the bug when I switch high-beams on and off sometimes, then I guess I think it's the switch.
    Maybe I'll take it apart to see if I can fix the connections in the switch rather than buying a new one. Or maybe I'll get one from a boneyard. I hate these OEM only parts!
  1. [Electrical] Fix/Rebuild Combo Switch, Low/High beam headlamp switch
    By russiankid in forum How To
    Last Post: 07-09-2013, 07:50 PM
  2. low beam headlights 89 accord not working
    By accord1989 in forum 3geez Accords
    Last Post: 04-30-2010, 09:21 PM
  3. high beam flasher circuit?
    By lostforawhile in forum Carburetor Tech
    Last Post: 03-28-2007, 07:22 PM
  4. Headlights not working on low beam
    By Luis 89LXi in forum 3geez Accords
    Last Post: 10-26-2004, 03:59 PM
