Results 1 to 4 of 4
Thread: cutting aftermarket springs
    SEi User Mantis88LX's Avatar
    97 Dodge Neon
    Athens AL
    i have tokico 1'' drop and i want to cut them to lower 1 and half inchs, how much should be cut off the springs?
    YK86's Avatar
    Oct 2000
    BC, Canada
    If you really want to do that, the best place to cut is the "dead" coils at the top of the spring BUT this would require you to use something like a chop swap that will cut the whole top end flush again. That way, you are only cutting off the coils that don't really do anything. If you only have a hand grinder, start with a 1/4 coil cut from the bottom and see how much that drops it. Again, make sure you really want to do this because you can never replace a cut coil.
    www.b20accord.com
    SEi User jigga225's Avatar
    Louisiana
    last resort....
    If you screw up... you can get a 2" drop from nopi.com for 97 bux
    hondaman87's Avatar
    88 honda accord DXE-i H/b 91honda accord wagon, 01 gsxr 600
    medford, mass
    you can cut 1 1/2 loop
  1. Valve Springs, aftermarket:which ones?
    By HondaBoy in forum Performance
    Last Post: 12-15-2009, 02:22 AM
  2. Cutting the springs...questions
    By Mattphi in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-21-2004, 05:40 PM
  3. cutting springs, help
    By Mantis88LX in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-12-2002, 09:11 AM
  4. cutting aftermarket springs
    Last Post: 07-10-2002, 01:23 PM
  5. cutting springs
    By wc-623 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 05-06-2002, 10:03 PM
