Hey
I have a 88 lx accord. It has developed a problem with the idle. When the car is started it will not drop below 2000-2500 rpm until the engine gets up to its regular temperature. Once it gets hot enough(after 5-10 min) the idle drops to normal(after i tap the pedal) and the engine runs fine. I have looked at the idle screw and it is set correctly. I believe there is something forcing the throttle to stay open until an even occurs. I think it might be the a/c boost thing but im not sure. If anyone has any suggestions it would help.
Also, i failed emissions any tricks to pass.
