What are the consequences,if any, of over tightning your valve cover nuts?
Well I imagine you could ruin the valve cover gasket at the least, possibly snap the bolts. Why so?
-Aaron-
Maybe the valve cover would leak oil, over tighting might break the seal....
I don't think you'll damage the seal as much as you will damage the studs that hold it down.
Eric
You would probably bend and possibly fracture the valve cover before you kill the studs. However, you might be limited by bottoming out on the nut first, I dunno. Why?
2003 Element Sunset Orange
2002 S2000 Spa Yellow
1999 CRV EX 4WD Auto White
TRADED: 1988 Accord LXi Sedan Auto White/Maroon
Had: 01 Civic EX Coupe, 00 3.2TL, 95 Integra GS-R Coupe, 92 Civic EX Sedan, 88 Legend Coupe LS, 88 CRX Si
just wondering cause i just changed my valve cover gasket and i know your supposed to use 7pds. of torque for the nuts. I just tightened them with a ratchet.
hand tight is good enough.. it it leaks.. a little more.... till it doesn't
when you've used toooo much.... you'll know.
*** SNAP **.... DOH!
CoAsTeR
88' Honda Accord LX
www.coastersride.cjb.net
Visit my website for pics and how-to's
