Results 1 to 5 of 5
Thread: wheel size for 87 lxi?
    Mar 2003
    87 accord lxi hatchback
    east corinth vt
    Question wheel size for 87 lxi?
    my 87 lxi hatchback that i just got has 185 70r tires on 13" rims. is this what came stock, or did some come with 14's? i would like to put 14's on if i can find rims to fit and if the clearance is ok. thanks guys
    LX User Gregs89AccordLxi's Avatar
    1989 Honda Accord Lx-i Sedan
    High Desert, Southern California
    Hey Welcome to the board! From what i know the Lxi's came stock with 14 inch rims, mine came with 14 inch honda alloys.
    1987 honda accord lxi 4dr
    Reading, Pa
    i have an 87 lxi and mine came stock wit 13in rims yea well upgrading to 17's soon but mine are 13 the 88-89 came wit 14's cause my dads came stock wit 14's and his is an 89 my friends sister's is an 88 and it came stock wit 14's and my friends sei has 14's
    Mar 2003
    1989 Honda Accord LX-i, 1978 Volvo 245 DL (Turbo Conversion)
    Cincinnati, OH
    Hey!
    The '86-'87 LX-i sedan came stock with 13 inch alloys, the hatchback came with 13" with steel wheels/hubcaps. '88-'89 had 14" in the same setup, hubcaps for the hatchback and coupe, and 14" alloys for the sedan, and then machined aluminum 14"ers for the SE-i.
    Alexi3rdgen
    86 Honda Accord LXI HB 5-sp
    Central California
    Re: wheel size for 87 lxi?
    As a bunch of people have already said, it came with 185/70-13's.
    You can run the same 14's that the 88-89 LXI's and SEI's run, with no clearance issues. Providing you run the right tire size, 195/60-14. Make sure to check out what it would cost you to do 15's, instead. You might find that for not much extra, you can have a better looking rim/tire combo. Correct tire size for 15" is 195/55-15 or 205/50-15, make sure that the rims aren't used honda rims or acura, that they have a offset no lower than 40mm and not higher than around 45mm.
  1. Which wheel is the drive wheel?
    By jteuton in forum 3geez Accords
    Last Post: 10-25-2006, 11:48 AM
  2. What is the best tire size for a 16x7 wheel?
    By aerokid1987 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 01-16-2006, 12:29 PM
  3. outer wheel nut size?
    By myaccord7 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 07-29-2005, 10:45 AM
  4. What's the best wheel size for my car???
    By HondaBoy334 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 12-19-2003, 05:43 PM
  5. Wheel Size's
    By 2Fast_Fiero in forum Suspension/Wheels/Tires/Brakes
    Last Post: 09-15-2002, 01:04 AM
