Results 1 to 6 of 6
Thread: pop up headlights
    Feb 2003
    86 accord
    upland california
    Question pop up headlights
    my drivers side headlight sticks as it go up or down. how can i fix it??
    Oct 2001
    87 Accord EX , 5spd , Manual
    put some wd 40 and check if anything is in the way !
    MIKE
    LXi User Nospeed's Avatar
    Oct 2002
    87 busted ass hatch
    Salem, OR
    you could always use a hammer.
    duct tape, a sledgehammer, bubble gum, and toothpics will fix anything. ANYTHING.
    - Justin
    Use a crowbar. I am being dead serious. Have someone pop the headlight up and down while you stand out there and figure out where it's sticking. Just stick the crowbar in there and bend slightly. It worked for me, however, my new headlight assembly is coming soon if that tells you anything. My advice, do it in slow increments or you'll be screwed over like I am.
    Also. Don't use WD-40 as it tends to dry out and cause the same, if not bigger, problems down the road. Just use lubricating oil.
    Nov 2002
    Ridin Dirty in New York
    use white lithium grease, that stuff works great. Also sillicone is great too because it doesnt degrade rubber and plastic like wd 40 somtimes can
  1. jdm headlights anyone????
    By guaynabo89 in forum 2geez Accords
    Last Post: 04-05-2009, 01:26 PM
  2. H4 Headlights
    By alanizgod in forum Interior & Exterior Care
    Last Post: 06-16-2007, 01:45 PM
  3. My new H4 Headlights
    By teck in forum Interior & Exterior Care
    Last Post: 01-30-2007, 02:18 PM
  4. headlights
    By ang1699 in forum 3geez Accords
    Last Post: 01-07-2006, 09:16 AM
  5. Headlights
    By BlueBead in forum Interior & Exterior Care
    Last Post: 10-10-2005, 09:30 AM
