Results 1 to 9 of 9
Thread: jdm b18a head on crv b20 block
    Mar 2003
    I was wondering if any of you guys know if it is possible to put a jdm b18a head on a b20 block from a crv? I need to know this because i got a 84 crx hf and want a engine swap but don't wanna go efi
    turfnnsurf's Avatar
    Nov 2002
    1991 Eclipse GSX AWD TURBO
    central NJ
    IM just curious?? why don't you want to go EFI??
    Friends Don't Let Friends Drive Stock!
    [email protected] Englishtown, 4/24/04
    2005 It's 12's or bust!! All BOOST all the time!
    LX User wickedaccord's Avatar
    SoCal VinDictor
    it is possible. either way if u want to do a b20b/z block in ur crx. regardless of which b20 block u want to use, u HAVE to use a b18 head anyways. it is becuz ive already done a few swaps for crx's and 90 civics and u CANNOT use a b20 head. it is TOO big. the b20 head will hit the hood and sit too high. that's y all the guys who go b20 in their crx's or 90 civics and even 90-93 integras use b18 heads to make room. but that b18 carb head will fit jus fine. jus remember that all vtec heads r interchangable with other vtec blocks. same goes with the nonvtecs. a friend of mine recently did a b20a with a b18b head on it. worked out fine. that motor fully built, port polish with the whole jg valve train using 301 cams, using 11.5comp pistons, eagle rods, chipped ecu, did 15.3 on the quarter mile with street tires.
    jon
    benson\'s 2.0 resleeved GSR block, PnP b16 head/multi angle valve job, ctr cams, hondata i/m gasket, str 68mm t/b, skunk springs/retainers, hondata s200b p30 ecu, LSD cable tranny, full race stage3 GT turbo kit (GT35R) custom 3 inch exhaust
    www.full-race.com
    Mar 2003
    the reason i don't wanna go efi is that i like simplicity and hate messing with computers, yes i know i might not have as much power potential but carbs are fun!
    hey thanks wickedaccord so its possible correct?
    i was just wondering have you ever done a carb'd b18 head on the b 20 though cause it sounds like you done the fuel injection.
    and when i refer to a jdm b18a head i mean one from a 2g lude or 3g accord cause well they're carb'd...thanks for the feedback hope you can answer this one
    SoCal VinDictor
    thanks, but ive never delt with a carbed head on a b20 before. jus becuz all the guys who wants swap.. u know do efi's. but i know wat u mean about the carbed head. keeping it simple is the best way to do it. and if ur gonna do it, do it right the first time. to be honest, the carb swap to another carb engine should be a lot easier to do than from a efi engine to another efi engine. it's like u said, dealing with ecu's isnt really fun if u dont know wat ur doing. good luck with ur swap. late
    jon
    www.full-race.com
    SEi User gr3k0sLaV's Avatar
    Feb 2002
    1998 VT Commodore 50th Anniversary Edition
    Geelong, Australia
    Carbs, so primitive. May as well throw in a new set of pushrods, and a mechanical water pump to complete the effect :P
    Cocaine's A Helluva Drug! - Rick James
    I really fracked things up for you Bill - Colonel Tigh
    Girl we couldn't get much Higher! - Light My Fire
    Mar 2003
    yes i understand what you are and almost everyone i run into are saying i do not blame you for feeling that way but i'm not going to way back with a hand crank start or anything i just prefer carb i am thinking this can be done because since i have found out on ludespeed.com that a gsr head on a b20 90 prelude block swap has been successful considering how they were completely different engines except for the fact that they're both b series and yet the swap was carried out successfully than why not a carb head on a crv b20 block? if they could mate a gsr b18c head on a b20 prelude block then why can't a b18a head be mated on a crv b20?
    Mar 2003
    Mar 2003
  1. comparison between jdm b18a, b18a1, b18b head
    By hafizi01 in forum 3geez Accords
    Last Post: 01-27-2010, 11:23 AM
  2. h22 head on b18 block
    By Young_j28 in forum Performance
    Last Post: 04-26-2008, 09:35 PM
  3. 87 head on a 88 block?
    By myaccord7 in forum Performance
    Last Post: 12-28-2005, 04:38 AM
  4. B18A manifold -----> A20A head
    By Sabz5150 in forum Performance
    Last Post: 09-24-2003, 06:21 PM
  5. del Sol head on A20 block
    By rbeaud in forum 3geez Accords
    Last Post: 07-01-2002, 04:02 PM
