It is true that a Bseries Ecu is needed due to different injectors and TB and what not? I didnt think it was something that was required...
You're lucky I got to you first....But naw, you don't need to change your ecu but you do have to make sure that when you get injectors that fit the b16 fuel rail that they are peak and hold, just like our accord setup......
yah you were right, you just need compatible injectors, fuel rail, and TB![]()
The B18A intake manifold needs the PR4 ECU
I need these parts!
Well, just get the b16 mani. and you're straight........![]()
