Results 1 to 3 of 3
Thread: Loose Front End!
    Mar 2003
    '89 Honda Accord LXi
    Vermont
    Question Loose Front End!
    My car sounds like the front end is loose whenever i hit a bump in the road. It sounds like i didn't tighten all the lugg nuts on my tires but i have. Im geussing maybe the bushing are f***ed but if anyone else has a similar problem or a way to fix it tell me. Also if anyone has any ideas if its something else.
    SEi User
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Check your front wheel bearings. Just jack up the car, and try to tilt the wheel out at the top and bottom (top and bottom of wheel moving in and out).
    Also check the bushings like you said, and if you need any, I have some brand new Honda bushings for sale.
    Also check stabilizer bar and the bushings.
    Actually test your suspension first. Push one side down, it shouldn't bounce more than 1-2 times.
    1987 Hatchback phreak project
    NORTH BAY ONTARIO
    lol.. you have problems?? i need both wheels bearings, and upper and lower ball joints... my car clunks and shakes when ever i hit a bump
    Travis
  1. Left front wheel axle nut found loose
    By Buzo in forum Suspension/Wheels/Tires/Brakes
    Last Post: 04-03-2011, 07:34 PM
  2. loose streering
    By johnypimpin2005 in forum 3geez Accords
    Last Post: 11-10-2004, 08:05 AM
  3. loose suspension???
    By NXRacer in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-02-2003, 04:02 PM
  4. my ass end gets a little loose
    By marc49 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-14-2002, 06:49 PM
  5. let loose
    By mag_pbg in forum Classic Honda Community Chat
    Last Post: 06-14-2002, 12:23 PM
