Results 1 to 12 of 12
Thread: getting to much fuel
    Feb 2003
    Black 89 accord LX-i Sedan
    Dallas,Tx
    OK here is my problem, I have an 89 LX-i programed fuel injection model and it seems to be getting to much fuel. The emissions fumes are pretty bad. I am unsure what to do. I also have 2 of 4 injectors leaking they are the middle ones. Could the injectors leaking make it run rich. My milage on the car is 207,000 miles. I am going to fix the leaking injectors with an O-ring kit from autozone. So can any one help me with the running rich, I know you guys can thanks.
    Jun 2001
    88 lxi coupe
    gainesville, fl
    Does the computer throw any code?
    Feb 2003
    Dallas,Tx
    no computer code as far as I know. No check engine light either.
    Bow to the Atlanta Braves
    89 Accord Se-i
    St.Charles, Mo
    Put 02 sensors on 37$ a piece from advanced auto parts that should fix the problem
    2.0Si User buzzbomber88lx's Avatar
    1985 Toyota Celica GT, 86 accord lx-i, 89 supra turbo
    Kansas
    I don't think o2 sensors would fix a fuel problem would they?
    1985 toyota celica 3sgte project
    1989 toyota supra turbo
    1986 honda accord 4dr lx-i
    1988starter
    Guest
    Well they do controll the air fuel ratio
    LXi User 89NinjaAccordLX's Avatar
    Jun 2001
    2013 Tricycle
    Brooklyn
    Well, I know this sounds retarded but why not get a voltmeter and just test the o2 sensors. Basically just see if there's voltage getting to the sensor.
    Banned cruznz's Avatar
    Jun 2002
    86 2.0Si JDM DOHC Accord
    Definitely get the injectors fixed, check your idle,check for vacuum leaks ,check ect sensor too
    if O2 sensor is tested .......a reading of .6v--1.0v , with engine idling or at a high rpm, and the reading stays constant means it is faulty
    Jun 2001
    88 lxi coupe
    gainesville, fl
    How was the emmissions readings like?
    Feb 2003
    Dallas,Tx
    Well the thing is that my check engine light hasn't came on. I fill like it is idled to high. It stays at about 1100 to 1200 rpm at idle.I havn't really checked for vaccum leaks because there isn't that many vaccum hoses to check on the car. I thought maybe that if the emissions or sensors failed maybe the check engine light would come on. Since it is PROGRAMED FUEL INJECTION I don't want to adjust the injection system. It isn't drivable because of the CV axels need to be replaced, so I can't put it on the dianosics computer. Thank you guys for your help and I will try all of the above.
    Jun 2001
    88 lxi coupe
    gainesville, fl
    What makes you think that it's running rich?
    Turn the screw on the throttle body with a flat head clockwise (i think) to lower your rpm to 750-800 when the engine is in normal operating temperature.
    Feb 2003
    Dallas,Tx
    The thing that makes me think that it is running rich is that it is ideling to high when I crank it up. As it runs the rpm's slowly go down. And while it runs I can smell the exuast fumes that are heavy. And I am outside by the way. I am just afraid that I will not pass emissions test. I am in Dallas Texas and the inspections are very strict.
  1. Fuel Assembly , Pump , & Fuel System Location
    Last Post: 05-10-2016, 01:27 AM
  2. Replies: 0
    Last Post: 03-07-2012, 02:07 PM
  3. Replies: 2
    Last Post: 12-15-2006, 07:25 AM
  4. dirt fuel tank keeps clogging fuel filters
    By lamontlamont in forum 3geez Accords
    Last Post: 12-12-2005, 10:52 PM
  5. hepl cannot got fuel line off fuel filter
    By 88vert in forum 3geez Accords
    Last Post: 02-04-2004, 09:20 AM
