I need the ECU Codes for the 86-89 Honda Accord LXi.
And with the ECU Codes, how do I access them.
Check the faq.
Under the driver's seat, the ECU box is there. Just flip open the little access window and count the number of times it blinks. Put your key to on first.
So put the key to on, then look at the ECU Box (NOT THE CHECK ENGINE LIGHT?) and how ever many times it blinks, thats the right code. I found the codes. But how I access my codes on my Bishi and my brothers Dodge, is to turn the key a sertain ammount of times, then the code will blink through the check engine light.
yeah that's right. If you have a code on your Honda, then the check engine light will stay on when the engine is running. But you have to get down to check for the number of blinks on the ecu.
How many times will the code be shown until it moves onto the next code? Because at first all I read was a 6, then when I just looked at it now, it said 7, and then I just went back out there, and it was flashing 6.
It will show once and then repeat.
blink blink blink (1st code)...pause...blink blink (2nd code)...pause...blink blink blink (1st code)...etc.
