Results 1 to 6 of 6
Thread: power loss engine misses
    Jul 2002
    Ok I have an 88 lx-i and my car misses terribly most of the time(except during hard acceleration). I changed the plugs, wires, air and fuel filter. No change. The ECU is throwing code 12. This means a faulty EGR valve. Is it worth replacing the whole unit or could I diagnos and try to fix this myself?
    1988starter
    Guest
    get a haynes manual and it will tell you check and replace also make sure all the vacume tubes are connected and you may want to check your timing.. Another thing many times all you need to do is clean it out real goods like with carb cleaner or something.
    Nov 2002
    '89 Accord LX-i
    Poughkeepsie, NY
    dist cap and rotor...
    Mods:
    90/91 CRX Si Wheels on Yokohama's, HP Racing 4'' oval exhaust, Arospeed Coilovers (0-4" drop, slammed at about 3.5" now), Modified Integra Short Ram Intake, Clear Front Bumper Lights(wired on w/ hyperwhite bulbs), Sidemarkers, White Interior Trim(Console, Vents, Handles, etc...), Removed Emblems, Type-R shift knob, Aiwa CD Deck, Sony Xplod 6x9's
    17.06 @ 80.9 mph
    http://www.cardomain.com/id/slammedlxi
    Nov 2002
    Ridin Dirty in New York
    yeah but if its throwing a code its prolly what it says it is. Id just get an egr gasket and get another egr valve and put it in... it takes like 15 min if that
    DX User lil 89 Lxi's Avatar
    89 Accord Lxi
    Hicksville indiana
    the EGR is the easiest thing to replace so i would do that and save urself the trouble of beating around the bush
    Y in a world of free speach are there phone bills??
    If u find your self in a hole the first thing to do is stop digging
    10/Honda/Ridgeline
    NJ
    two 10mm bolts and the egr valve comes out. swap it out with one from the junk with a new gasket and see if it still gives u the code. Also, try resetting the ecu and then start the car and drive it around for a while before u go ahead and start changing anything.
    NOTE: this is not related to performance so next time post appropriate threads in the proper sections not based on which sections u get more users. :smokin:
  1. Power Loss
    By Techno in forum Performance
    Last Post: 09-05-2003, 09:54 PM
  2. Power Steering. . power loss?
    By bboipinoy112 in forum 3geez Accords
    Last Post: 08-11-2003, 07:47 AM
  3. Engine Misses?
    By Janiel in forum 3geez Accords
    Last Post: 03-06-2003, 09:32 AM
  4. loss of power sometimes
    By Slamed89Accord in forum 3geez Accords
    Last Post: 02-19-2003, 08:10 PM
  5. Engine misses above 3k rpm...
    By vtec11 in forum 3geez Accords
    Last Post: 07-29-2002, 01:44 PM
