Page 2 of 2 FirstFirst 12
Results 26 to 30 of 30
Thread: 86 carb venturi spraying gas
    Yeah, I knew it was a leaky jet...
    hmm now now now... what shall I do.
    See I can see where Pos was coming from... I was thinking there was a need to syphon in gas into the pump diaphragm... but I thought it was all based on the spring.
    so hot = open means less fuel because you don't need as much.
    ... unless you want some performance. I hope.
    So Eric... I think I'm gonna give it a try...maybe pump water instead of gas with the carb off the car.
    OH and DAN if you have anymore cutaways of the keihin let me know.
    Oct 2001
    87 Accord EX , 5spd , Manual
    BTW teh Primary slow solenoid makes a click sound when ignition is turned !
    ask some one to turn the ignition on while your fingers are on it !
    you will hear and feel the click !
    good luck !
    MIKE
    where did u get that diagram?????
    LX User DanG86LX's Avatar
    Jun 2002
    86 Accord LX, carb, AT
    Edmonton, Alberta
    Helm manual, 61SE300
    Mar 2003
    1986 honda accord/carb
    Finally figured it out:
    1.The Carb was spraying fuel due to a major vacuum leak from the rear intake tube just behind the carb
    2. After fixing that and rebuilding the carb i was able to get the car to idle down 1000rpm, but was extremly rough, #3 wasn't firing properly, cap and rotor was shot.
    3. car runs like a gem now
    4. My Headache is gone
  1. Replies: 21
    Last Post: 12-02-2018, 03:41 AM
  2. carb cleaner fixed my problem while i was spraying it
    By bwallace530 in forum Carburetor Tech
    Last Post: 04-04-2009, 08:43 AM
  3. Variable Venturi VS. Fixed Venturi carburetor?
    By dat in forum Carburetor Tech
    Last Post: 03-16-2008, 06:41 PM
  4. spraying my bumper and moldings advice
    By howndamane in forum Interior & Exterior Care
    Last Post: 07-19-2004, 04:18 AM
  5. loose venturi?
    By Mantis88LX in forum Carburetor Tech
    Last Post: 02-27-2003, 04:37 AM
