I'm on the 3rd day of carb to EFI swap. I swap isn't really hard. There is no big mods you have to do to get it work. basically unbolt here and unplug wires here then make your swap. The biggest thing you need is some patients because you are going to run into some tight spots and some things are not going to come apart as easily as they should. The entire swap will take me about 5 days but I'm in no rush.
