My amp, when paused, makes my subs rumble low.. if I turn the EQ or Gain up a little the subs fucking rumble BAD...
Anyway I could correct this?
Same thing happens in my car. For me, it's because I bought one of those generic wiring kits off eBay for like $20, instead of spending a few hundred on name brand shit. Most of the problem is due to bad RCA's. I'd also say a bad headunit, but Alpine isnt generic. RCA's/wiring kit is the problem.
yeah try new shielded RCA cables or re-grounding the anp
86 white hatch LXi with 5spd swap and full system.
If it's like mine, the ground is okay. We've used two different grounds, and the first one was an unpainted bolt, on an unpainted surface (in the trunk) and it still did it. I think you just might need to shell out the $120 for a good pair of Fosgate RCA's. I havent done it yet, I can live with the sounds lol.
