Results 1 to 6 of 6
Thread: wheel sizes
    Justin86's Avatar
    Medford, Oregon
    wheel sizes
    How wide of a wheel can we safely go on our 3g's. I have been thinking about trying to get some 7.5" or 8" wide rims. I have seen a Supra run 19"x8" in front and 19"x12.5" in the rear and they look real nice. Also that Supra in pushing 1,200hp! :badass: Right now I have 17"x7" rims and I think that some wider rims would look sweet. So what size rims can I use?
    86 Honda Accord LXI HB 5-sp
    Central California
    I wouldn't run anything wider than 7.5" and you cannot run wider than 215mm tread widths anyways. I hear stories about running 19's on a 3rd gen, but no pics and no proof. When looing at 18" rims make sure they have 45mm offset, it's not worth the risk of having to roll the rear fenders (which might not be enough to stop the rubbing).
    86AccordLxi's Avatar
    Oct 2000
    1989 240sx FB,
    Salem, OR
    Hey Jim, i've got a question: I just purchased a set of TSW rims (look in sig for pic :pimp: ) and the tires are 205/40 16. The tires did rub on the lips with 2 passengers and a trunk load of stuff, so I rolled the rear lips, which fixed that problem. I'm not entirely sure what the offset is on the rims, but I'm almost positive that it's less than 40mm. There is no problem now, but if I switch to the correct size tire (205/45 16), do you think that the rubbing problem will come back?
    Alex
    goldyaccord's Avatar
    Ford work Van
    Tigard, Oregon
    Alex
    You must have gotten 38 or 35 mm offset. What car was it on before?
    sorry guys v8's rule
    Oct 2000
    1989 240sx FB,
    Salem, OR
    A CRX, which should have the correct offset, shouldn't it?
    Alex
    Justin86's Avatar
    Medford, Oregon
    I have 17" rims right now and I was told they were 38mm offset, and I have a 2" drop with no problems of rubbing. I have hit some good size bumps and have cranked the steering wheel completely and no rubbing, so go figure.
  1. Front Wheel bearing sizes?
    By 79cord in forum 2geez Tech & Performance
    Last Post: 09-02-2010, 05:26 PM
  2. Wheel sizes 83 sedan
    By accord83 in forum 2geez Accords
    Last Post: 04-04-2009, 12:50 PM
  3. Wheel sizes ---> speedometer adjustments
    By Whistler225 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 08-14-2007, 08:36 PM
  4. Wheel Sizes......
    By iloveJDMblackrims69 in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-07-2003, 02:09 PM
  5. New to wheel sizes!!
    By MC Pee Pants in forum Suspension/Wheels/Tires/Brakes
    Last Post: 06-14-2002, 06:18 PM
