What the hell is up with this friggin carb:
Rebuilt the damn thing
idles for a while until it gets warmed up
then she coughs and bucks the dies
will not start back up unless i hold the pedal down
check all 40 million vacuum lines
what gives?
what gives?
Maybe your throttle stop screw is set out too far such that when the fast idle gets unloaded it gets nada. See if turning in some helps, and I dont mean giving it super high idle using the screw just to cover the problem.
Check to see if your choke opens when warm so that the engine isnt getting drowned in gas. Do this first!
Have any of you expereinced worn throttle shafts? i spray carb cleaner at the shafts outside of the carb and the engined reved right up..............the car has 150k on it.
Mine is doing that by about 20rpm. Lil wear guess.
Did u replace the base gasket, strange looking one?
OK, CHECK THIS OUT, MY CAR IS BOGGIN DOWN WHEN I GO TO PUT THE PEDAL TO THE FLOOR. SO I REPLACED THE FUEL FILTER AND THE FUEL PUMP AND ITS STILL DOIN IT AND I HAVE NO CLUE WHAT IT WOULD OF BEEN SO I STARTED TO THINK IF IT WAS THE FIRING ORDER AND IT WASNT THAT SO I HAVE NO CLUE WHY ITS BOGGIN DOWN WHEN I GO TO PUT THE PEDAL TO THE FLOOR
its a loose booster venturi... maybe
WHERES THE BOOSTER VENTURI
accord86,
check the accelerator pump by opening the butterfly (choke plate) and while looking down at the primary barrel blip the throttle and you should see a stream of fuel squirt out of the
pump tube going down the barrel.
wheres the booster venturi located
also check the spring on the accelerator pump... sometimes the spring gets weak and there is a small delay in the the squirt.
and it could also be the ignition timing. or a vacuum leak.
here is a link for the booster venturi.
https://www.3geez.com/showthread.php?...ooster+venturi
