Results 1 to 3 of 3
Thread: Idle Fluctuates -need Help?
    1988 accord lx
    oklahoma
    Angry Idle Fluctuates -need Help?
    IDLE IS BAD ,UP DOWN UP DOWN,STAYS BETWEEN 1400 AND 1600 RPM'S . COULD SOMBODY HELP THE LITTLE CAR THAT COULD. THANKS ALSO IT IS CARBED IF IT HELPS.
    d.e.
    Re: Idle Fluctuates -need Help?
    I think there's your problem.
    lol j/k
    most likely it's a vacuum leak, sounds like maybe the idle control thingamajig (I forgot what the piece is called, it is connected to the same bracket as the accelerator pedal cable by a rod that goes to a dashpot with 1 vacuum line. Take off the hose and see if there's vacuum there.
    Vacuum leaks are most easily found by using carb cleaner spray. When you spray it near a vacuum leak the motor will suck it up and you'll hear the RPMs go up momentarily.
    Eric
    1988 accord lx
    oklahoma
    thanks i check it
    d.e.
  1. Replies: 18
    Last Post: 11-03-2009, 05:42 PM
  2. Weber Carb - cold idle fine, warm idle too high - help?
    By it's paid for in forum Carburetor Tech
    Last Post: 02-21-2004, 09:11 PM
  3. RPM fluctuates on left turns
    By drknow in forum 3geez Accords
    Last Post: 09-28-2003, 02:57 PM
  4. is there a way to lower my fast idle, but keep warm idle the same?
    By bobafett in forum Classic Honda Community Chat
    Last Post: 03-20-2003, 05:44 AM
  5. 87 Accord, Dies, idles erratically, fluctuates etc....
    By styxandstones in forum Carburetor Tech
    Last Post: 09-03-2002, 08:47 AM
