Results 1 to 23 of 23
Thread: Changing Belts
    SEi User wallyyfm's Avatar
    '88 Accord LX (Sold), '94 Buick LeSabre "The Tank", '86 Lxi New Project
    Northern New York
    Changing Belts
    Well guys, i've done alot of things to my 3 g, but i've never had to change the belts. I got one that squeaks horribly and i really cant tell which one it is. So, im gonna replace all of them, who knows when they were replaced last. But how do i go about doin this? It's awfully cramped in there. Do i take off the alternator, and where is the tensioner adjustment? This is about the only thing i've never had to do and just dont know how to start it.
    Thanks
    SEi User 89accord_lxi_coupe's Avatar
    Jan 2003
    Louisville, TN
    i'm almost certain the how-to section has a listing for this. try that, then ask any other questions you might have. also get a haynes or chilton manual, they are a big help.
    -Nolan
    Nolan
    check my profile
    I'm on AIM at Maxaccord3G
    I AM THE STIG
    Northern New York
    i looked in the how to, couldn't find it, i have a haynes, but it doesnt really show anything useful, which kind of surprised me
    LXi User 88WhiteLX-i's Avatar
    Jan 2002
    White 1988 Honda Accord LX-i
    Massachusetts
    Well first determine which belt it is. Because it its your alternator/water pump belt you have to take off your power steering and ac compresor belt. To get at your Alternator belt, first take off your air filter box so you can get to the bolts to loosen up the alternator. After that you loosen up the power steering bolts and slip that belt off. Next is your AC belt, if you don't care about it or if it doesn't work you can cut the belt, it'll give you more power anyway. And then your alternator belt. Please ask if any more questions.
    R.I.P. Died on 7/2/03......
    Northern New York
    I'm gonna get the rest of the belts tomorrow. I just have the main drive belt and i will do all of them. Prolly try tomorrow night. Thanks
    87 Accord LXi Hatchback
    Chicago
    Let us know how it went....
    SEi User 88 Accord DX's Avatar
    '95 del Sol VTEC
    San Angelo, Texas
    man belts are a bitch to mess with. its so fucking crowded. when i had to do the A/C belt, i had to get up under the car and try and do all of it. it was bullshit. i did all that just to have it fall off the next day.
    -T.C.
    Oct 2001
    87 Accord EX , 5spd , Manual
    A/C belt is really a bitch !
    BTW the service manual is avaialble for download in the FAQ's !
    MIKE
    Northern New York
    well tonight, after workin on my friends dirtbike, we rolled in my 3 g to do belts, after 3 beers and bleeding knuckles i said "well fuck this" so i just tightened up the slack with the alternator adjustment, the belt still squeaks some at idle, but doesnt scream like it did, it'll be good enough until one breaks, then i'll changem
    Oct 2001
    tighten it more ! if that helped !
    MIKE
    Northern New York
    i dunno, the belt is pretty tight, i dont wanna snap it
    Oct 2001
    are you sure it's the one making a squeek ??
    BTW tighten the PS belt too ! it's pretty easy to tighten it !
    MIKE
    snapper's Avatar
    Jun 2002
    '89 Accord DX
    Sea Bright, NJ
    I did the alternator and power steering belts this weekend. I gave up on the AC belt because the adjusting bolt is frozen. I ended up just cutting AC to get to the alternator belt. The car doesn't squeek anymore, but I have no AC. Mike is right though, the power steering it easy enough to tighten. I know this was actually the one that was making the noise on mine.
    Honda was smoking crack when they designed some of the parts on our car. I had to get to my transmission dipstick today and cut the hell out of it just to get to it. That same goes for the belts.
    Northern New York
    yeah, why put the alternator in the ass crack of the car? its way down in the bottom, id never want to replace that, all my other GMs were right on top and easy to get to, this is why i want an EFI sometime, all these vacuum lines for the carb just piss me off
    snapper's Avatar
    Jun 2002
    '89 Accord DX
    Sea Bright, NJ
    Do you think I'd be able to cut of the adjusting bolt with a dremel? I tried with a saw zaw, but I couldn't get it in there. The bolt is shot, and I already have another off my junk car. It came off in two seconds from there.
    Oct 2001
    if you cut the AC adjusting bolt you'll have to get the lower mount bolt completely out ( not just loosen it ) so you can put th enew adjuste bolt in ! ( which is a bitch believe me )
    BTW did you loosen all AC mounting bolts before trying to remove teh adjusting bolt ??? ( 4 Mounting bolts , 2 of them with nuts ! ( DENSO compressor ) )
    put some WD40 on the bolts and let it sit a while !
    MIKE
    Mike's89AccordLX's Avatar
    Mankato, Minnesota
    I was looking at my belts today and they look like they need to be changed. I was wondering if I should just wait until I get underdrive pulleys.
    Oct 2001
    belt won't wait ! if they are in bad condition tehy can fail any time ! is the timing belt also bad ! if it is change it at once ! if it fails on you , it could cause a lot of damage to the engine !
    MIKE
    snapper's Avatar
    Jun 2002
    '89 Accord DX
    Sea Bright, NJ
    I have the keihin type so there is two bolts on the top and then the adjusting bolt on the bottom. I've gotten the two bolts on the top out and have even been able to pivot the compressor on just the bottom bolt. The nut it off, but the bolt won't budge to let me slide the compressor back. It is almost like the head of the bolt welded to the bracket. I took it off my other car in like two minutes. It's very weird.
    I figure if I can cut the head of this I can at least get the bolt out. It's not even threaded in the compressor. That's what is driving me nuts. I can't figure out how the hell it is still on there.
    I tried WD40 and pentraiting oil with no luck.
    Oct 2001
    you can cut the belt off ! then slide the compressor up , then you'll have clearance to cut it off ! just a thought !
    MIKE
    SEi User Morpheus's Avatar
    Jan 2003
    1988 Honda CRX Si
    How the hell do the mechanics do it?
    snapper's Avatar
    Jun 2002
    '89 Accord DX
    Sea Bright, NJ
    I already cut the belt off to change the alternator belt. I'm riding around now without any belt on it. The compressor won't budge. I've even use a crow bar on it and a sledge hammer. I'm going to try to cut the bolt I think.
    Mankato, Minnesota
    I don't think cutting bolts will be good for anything.
  1. Best way to replace belts?
    By infecto in forum 3geez Accords
    Last Post: 09-15-2004, 12:15 AM
  2. Squealing belts
    By meangreenLXi in forum 3geez Accords
    Last Post: 03-07-2004, 07:37 PM
  3. squeaky belts
    By GDGuy11B in forum Classic Honda Community Chat
    Last Post: 11-17-2002, 05:47 AM
  4. belts?
    By franks89sir in forum 3geez Accords
    Last Post: 11-06-2002, 09:22 PM
  5. Belts
    By accordboricua in forum Performance
    Last Post: 09-07-2002, 09:00 PM
