Guys,
I see these guys listing "Removed Cruise Control" as a performance mod. What the hell does that do? Is there any more power or are they just running out of things to list?
Bruce
VA
Guys,
Bruce
VA
Engine Mods:
Milled the head
Advanced Timing
Adjustable fuel pressure regulator
New Injectors
Cool Air and Ram Air kit
Dismantled EGR Valve
Pace Setter Header 4-2-1
No Cat into a Pace Setters muffler
where did you see that?
most likely, if it says to remove cruise control that means it won't work after the mod.
thats very true. I mean, if you went turbo say goodbye to reliable cruise control operation. I ditched mine because it stopped working and i dont use it anyways
Here it is, This is off of Mike's89AccordLX SEi User
It is the Tenth thing on the list right before the Deltacam 272.
Performance Mods:
Weber 32/36 Downdraft Carb, Weber 3" Air Intake, SI Rims, Arospeed Exhaust System, Stage II Clutch Kit, Pacesetter Headers, Bolt On Straight Pipe, Custom Rear Strut Bar, Removed Vacuum Lines, Removed Cruise Control, Deltacam 272, Pacesetter Short Shifter, AEM Air Bypass Valve, Accel Super Stock Chrome Ignition Coil, Toucan 9mm Plug Wires, NGK Power V Plugs, Custom Plexi-Glass Ram Air Box, Optima Red Top Battery, Moddified Gas Pedal To Get To WOT. Awaiting the install of my hoodscoop. And currently working out to lose some lbs. so the 3G will go faster.
Apperance Mods:
Spent way too much on apperance mods.
Audio & Security:
RF Amp and Subs, 4 x Clarion 6.5" Speakers, Avital Security System.
Future Mods:
Ingalls Camber Kit, Lowering Springs, Koni Shocks & Struts, SE-i Front & Rear Sway Bars.
Engine Mods:
Milled the head
Advanced Timing
New Injectors
i think you are missing one point. he went with weber, which means he can't use cruise control anymore, so why would he keep it under the hood. i diched mine after i removed all the vacuum lines.
cruise control works on a vacuum. but if you remove all the vacuum lines what is the point to have it. it is just takes up space and weight.
Where is exactely the cruse control at. I'm planning on putting on a turbo and if the cruse won't work any more it is just dead weight and taking up space.
I guess he is just trying to let u know what he did to his car! He must be pushing 125hp...
-=PROJECT-=-
NOTE: Project-R Swap parts provided by Racing Impulse. Swap was Performed by RacingImpulse & Next Wave Auto Performance.
B-Series Wants You
It's the cable actuator and vacuum tank above the motor mount on the belt side of the engine. It's really not that much weight, but if it's not working, the free space would make other jobs somewhat easier.Originally posted by Justin86
Mike
ok i know i can remove most of it no sweat. but where does that cable end up that goes into the firewall? i dont want the cable hanging around in the engine bay if the rest of CC is gone. and i really am hesitant to just "cut" it...
so whats the trick? i want to get rid of my POS cruise contril, i never use it and it doesnt work with my steerting wheel!![]()
the cable connects to the accel. pedal.
it is very easy to remove.
sweet. bye bye CC!thanks shepard!
Hey thanks guys I will have to pop my hood and take out that POS.![]()
I have a weber and my CC works just fine....![]()
how did you connect the the CC?
no idea, bought it that way
after i install my momo steering i just rip my cc out, lol...
JDM CONCEPTwww.jdmconcept.com
1991 Honda Integra LS-Special
ok guys here a question my cc was working but not now how can i fix it LOL
the cruise doesn't connect to the carb, it conects to a special linkage on the gas pedal arm. it doesn't care what kind of carb you have. you have to have the cruise pedals it won't connect to a standard assembly.Originally Posted by shepherd79
everyone is pulling them out and i have a long term project putting that system in my dx. i thought the cruise was kinda cool. just don't try this project at home. if i ever get the time i will finally put in the pedals and hook up the cable. rest is good to go. even with modifing my seat to go back more my knees still bend at a wierd angle when i have my foot on the gas, so i'm looking forward to finishing that up for long trips. want to see my racing pedal assembly i made in my car not on my bench.Originally Posted by Justin86
i just want mine to work again was so nice on the long trips up north
get the chiltons book no. 6980 73-88 honda it will give you the entire diagnostic for the cruise system. really good pictures too. oh you might want to get a hand vaccume pump and gauge not just for this but for a lot of diagnostics in that book.
thx ill have to check that out
for everyones info when you put on a webber there is no need to remove the cruise control, it doesn't attach in any way to the carb, all it does is move your gas pedal just like you would move it with your foot. it has a cale that attaches to a special arm on the cruise pedal assembly the cable goes straight to the firewall.
does a webber make a dif in proformance ???? and how much of a dif !!!!!!
there are about a thousand posts on that around here this is a thread on cruise control i think you can look under search for the webber
